Spotted a black lancer with P plates on Hindmarsh near Kambah village obviously in a rush....protip: if you want to drive like a f**king tool, at least get a car with the balls to do so. Dropping the clutch like you're dragging me and then being mashed like a little girl before you even find the speed limit must have made your bangin' hot girl in the passenger seat wet as all f**k yeah? ;)
https://www.sau.com.au/forums/topic/30059-spotted/page/694/#findComment-6071259
lol^^
I got reminded why I didnt get a v8 snoarer on the way home.
one over took me on drakeford and planted it...it made lots of noise and very slowly went past...I loled
Hahaha!
I had a dude in some ugly looking thing I couldnt even tell what it was do this to me.
He pulled up at the lights and just sat there staring and rolling forward.
He then took of doing 0 - 60 in 40seconds flat
https://www.sau.com.au/forums/topic/30059-spotted/page/694/#findComment-6071655
i always drag race people in my 0-100km/h in 2minutes car because that way i feel like i won when i full throttle and barely manage to reach the speed limit before they do while they dont even know im trying to race them :P
https://www.sau.com.au/forums/topic/30059-spotted/page/694/#findComment-6072495
exactly this. hahaha
https://www.sau.com.au/forums/topic/30059-spotted/page/694/#findComment-6072524
Spotted Zane and Mel yesterday, I tried ghosting them Hamish and Andy style them in the supermarket but they caught on :D
Also spotted a black R33 today about 2pm on the Monaro where it goes over Canberra Ave.
https://www.sau.com.au/forums/topic/30059-spotted/page/694/#findComment-6076846
    • Hi...so a "development" here aswell The swap is "done" and car went "test drive" BUT it seems the clutch(maybe gearbox?) is a little bit sad? I bought this clutch kit https://justjap.com/products/xtreme-heavy-duty-organic-clutch-flywheel-kit-nissan-skyline-r31-r32-r33-push-type "Problem" is that the first gear is hard to put into and it seems that the clutch is not disengaged. It was not the problem with the old clutch...(or like sometime the first gear would not get as easy specialy when the fluid was cold) So? Can it be like...bad "install" or is the clutch wrong ((it should not have been) i done research to get the right one) Or is this "normal" with new clutch and needs to be break in?
    • @Duncan I can try  and thanks i did not thought about VIN and part numbers for 33/34. @GTSBoy yeah it looks like iam gonna do that
    • Forgot to include this but this is the mid section of my steering rack that looks like it has a thread/can be turned with that notch mentioned in the post:
    • Hey everyone, Wanted to pick some brains about this issue I'm having with rebuilding my 33 rack (PN is 49001-19U05). All of the tutorials/videos I've seen online are either R34 or S Chassis racks which seem to be pretty straightforward to disassemble but this process doesnt carry over to my rack. Few of the key differences that I've noted The pinion shaft on the other racks bolt on with 3 torx bolts: Whereas my rack bolts on with 2 allen head bolts: These changes are pretty inconsequential but the main difference is how you pull the actual rack out of the housing. The other skyline/s chassis racks can be taken out by tapping the rack out of the body with a socket and it just slides right out. I'm unable to do that with my rack because there's a hard stop at the end that doesn't let the seal/shaft be tapped out. Can also see a difference in the other end of the rack where mine has a notch that looks like you're able to use a big wrench to unthread 2 halves of the rack whereas the other racks are just kinda set in with a punch. My rack: Other racks: TLDR; Wanted to know if anyone has rebuilt this specific model of steering rack for the R33 and if there were any steps to getting it done easier or if I should just give this to a professional to get done. Sorry if this post is a bit messy, first one I've done.
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
