haha thanks. That was it. Needs a good polish though.
Do you know who's 32 it is? I saw them pull in today buy I had a soldering iron in 1 hand and balancing solder and wire in the other, didn't really get a chance to wave to them.
https://www.sau.com.au/forums/topic/30059-spotted/page/727/#findComment-6277413
Nah I dunno... I've seen it there for few months now.
I always look to see if it's there when I drive past and now I look for yours too! Lol. You new to the area? Don't drive down beside the golf course as they have recently put in an OVERKILL of speed humps. Never seen so many on one street. I used to do a lap round there to dry off a little after a wash. No more...
https://www.sau.com.au/forums/topic/30059-spotted/page/727/#findComment-6277443
Yeah, moved in about a month and a half ago.
It seems a really quiet area.
Except for the burnouts, donuts and 3rd gear redlining... (especially in the wet) yeah Holt is nice.
Hope you have alarm/immobiliser and stearing lock.
My Mrs had her capri stolen from my driveway a couple of years back.
WELCOME...
https://www.sau.com.au/forums/topic/30059-spotted/page/727/#findComment-6277492
Wow, i must miss all of that being on weird shifts :P
I guess it's no different to kaleen then. At least i'm closer to the cotter here.
That reminds me I should probably swap the skyline and the cressy round.
Edited by azathoth
https://www.sau.com.au/forums/topic/30059-spotted/page/727/#findComment-6277532
Yeah know what thats like - Took my mum to the hospital last week in the 34.
She's telling everyone the trip nearly killed her before she got there - and I went sooooo slow too.
Nxt time she's in for a real fright - I'll take the GTR !!!
https://www.sau.com.au/forums/topic/30059-spotted/page/727/#findComment-6281039
geez I turned right at traffic lights after stopping, she nearly screamed for no reason.
I've given her plenty of scares on purpose though, went round a roundabout at 80 (the speedimit) and she yelled 'slow down'
Im full of stories
https://www.sau.com.au/forums/topic/30059-spotted/page/727/#findComment-6281142
When I first got the 33 all those years ago my dad took my mum for a drive
She got out of the car and said "what do you want a car that fast for?" I loled
my mum told me I shouldn't drive so fast, I was like 'if this is fast for you, please buy me a turbo and I'll show you fast'
https://www.sau.com.au/forums/topic/30059-spotted/page/727/#findComment-6281225
    • Who did you have do the installation? I actually know someone who is VERY familiar with the AVS gear. The main point of contact though would be your installer.   Where are you based in NZ?
    • Look, realistically, those are some fairly chunky connectors and wires so it is a reasonably fair bet that that loom was involved in the redirection of the fuel pump and/or ECU/ignition power for the immobiliser. It's also fair to be that the new immobiliser is essentially the same thing as the old one, and so it probably needs the same stuff done to make it do what it has to do. Given that you are talking about a car that no-one else here is familiar with (I mean your exact car) and an alarm that I've never heard of before and so probably not many others are familiar with, and that some wire monkey has been messing with it out of our sight, it seems reasonable that the wire monkey should be fixing this.
    • Wheel alignment immediately. Not "when I get around to it". And further to what Duncan said - you cannot just put camber arms on and shorten them. You will introduce bump steer far in excess of what the car had with stock arms. You need adjustable tension arms and they need to be shortened also. The simplest approach is to shorten them the same % as the stock ones. This will not be correct or optimal, but it will be better than any other guess. The correct way to set the lengths of both arms is to use a properly built/set up bump steer gauge and trial and error the adjustments until you hit the camber you need and want and have minimum bump steer in the range of motion that the wheel is expected to travel. And what Duncan said about toe is also very true. And you cannot change the camber arm without also affecting toe. So when you have adjustable arms on the back of a Skyline, the car either needs to go to a talented wheel aligner (not your local tyre shop dropout), or you need to be able to do this stuff yourself at home. Guess which approach I have taken? I have built my own gear for camber, toe and bump steer measurement and I do all this on the flattest bit of concrete I have, with some shims under the tyres on one side to level the car.
    • Thought I would get some advice from others on this situation.    Relevant info: R33 GTS25t Link G4x ECU Walbro 255LPH w/ OEM FP Relay (No relay mod) Scenario: I accidentally messed up my old AVS S5 (rev.1) at the start of the year and the cars been immobilised. Also the siren BBU has completely failed; so I decided to upgrade it.  I got a newer AVS S5 (rev.2?) installed on Friday. The guy removed the old one and its immobilisers. Tried to start it; the car cranks but doesnt start.  The new one was installed and all the alarm functions seem to be working as they should; still wouldn't start Went to bed; got up on Friday morning and decided to have a look into the no start problem. Found the car completely dead.  Charged the battery; plugged it back in and found the brake lights were stuck on.  Unplugging the brake pedal switch the lights turn off. Plug it back in and theyre stuck on again. I tested the switch (continuity test and resistance); all looks good (0-1kohm).  On talking to AVS; found its because of the rubber stopper on the brake pedal; sure enough the middle of it is missing so have ordered a new one. One of those wear items; which was confusing what was going on However when I try unplugging the STOP Light fuses (under the dash and under the hood) the brake light still stays on. Should those fuses not cut the brake light circuit?  I then checked the ECU; FP Speed Error.  Testing the pump again; I can hear the relay clicking every time I switch it to ON. I unplugged the pump and put the multimeter across the plug. No continuity; im seeing 0.6V (ECU signal?) and when it switches the relay I think its like 20mA or 200mA). Not seeing 12.4V / 7-9A. As far as I know; the Fuel Pump was wired through one of the immobiliser relays on the old alarm.  He pulled some thick gauged harness out with the old alarm wiring; which looks to me like it was to bridge connections into the immobilisers? Before it got immobilised it was running just fine.  Im at a loss to why the FP is getting no voltage; I thought maybe the FP was faulty (even though I havent even done 50km on the new pump) but no voltage at the harness plug.  Questions: Could it be he didnt reconnect the fuel pump when testing it after the old alarm removal (before installing the new alarm)?  Is this a case of bridging to the brake lights instead of the fuel pump circuit? It's a bit beyond me as I dont do a lot with electrical; so have tried my best to diagnose what I think seems to make sense.  Seeking advice if theres for sure an issue with the alarm install to get him back here; or if I do infact, need an auto electrician to diagnose it.
    • Then, shorten them by 1cm, drop the car back down and have a visual look (or even better, use a spirit level across the wheel to see if you have less camber than before. You still want something like 1.5 for road use. Alternatively, if you have adjustable rear ride height (I assume you do if you have extreme camber wear), raise the suspension back to standard height until you can get it all aligned properly. Finally, keep in mind that wear on the inside of the tyre can be for incorrect toe, not just camber
