Richard, you can't admit to not knowing that!
Lots of differences but the easiest way between S1 and S2 is the front bonnet (has more aggressive grooves) and the front bar has those spotlight things.
spotted a nice red s3 r31 on the parkway around 4:40 got them to wind down their window and tryed to offer them a car, then had to get out of the way of traffic cos they slowed down to 80 and then didnt catch back up till i turned off when they proceded to give me the finger hahaha you twats
:blink:
https://www.sau.com.au/forums/topic/30059-spotted/page/731/#findComment-6302119
How do you tell the difference between an S1, S1.5, S2 and S3 R33? and R31 S1,2,3, ? etc....
When I was typing my question up I kept thinking who caresbut I would like to know coz Im ignorant when it comes to telling. Seriously I thought there were only two types of Skylines 1. GTR's & 2 Non GTR's
https://www.sau.com.au/forums/topic/30059-spotted/page/731/#findComment-6302129
Spotted a silver 33 series 2 with a Trojan sticker this arvo leaving Mitchell on the GDE. Big rich stain on rear bumper and ding on passenger side.
Gave a wave, got a look. :blink:
saw azathoth again the other day. :cool:
Edited by Not a Pulsar
https://www.sau.com.au/forums/topic/30059-spotted/page/731/#findComment-6303339
Think I've seen your 4dr around? or one that looks exactly the same.. In queanbo.
https://www.sau.com.au/forums/topic/30059-spotted/page/731/#findComment-6303599
Nah... Not me. Don't go to QBN very often.
I have seen maybe 2 other Dark Grey or Black 33 4doors around, 1 with a P plate, but you just don't see 4doors very often at all. :thumbsup: It's nice to be different.
Anyone seen/know of a 2 tone R33 coupe with Maroon roughly halfway up the door and black above that?
Saw it on Sunday near Majura Park shops. Twas perhaps a little disturbing...
https://www.sau.com.au/forums/topic/30059-spotted/page/731/#findComment-6303622
There is a black series 1 in QBN, plus my silver series 2.
Hey mate, is your Silver 4door the one that was FOR SALE about a year or more ago?
It was on Carsales and lived in Dunlop but was sometimes parked near the roundabout near Charnwood.
Would love to see it sometime... compare notes etc. :rolleyes:
https://www.sau.com.au/forums/topic/30059-spotted/page/731/#findComment-6304769
    • Yeah, that's fine**. But the numbers you came up with are just wrong. Try it for yourself. Put in any voltage from the possible range and see what result you get. You get nonsense. ** When I say "fine", I mean, it's still shit. The very simple linear formula (slope & intercept) is shit for a sensor with a non-linear response. This is the curve, from your data above. Look at the CURVE! It's only really linear between about 30 and 90 °C. And if you used only that range to define a curve, it would be great. But you would go more and more wrong as you went to higher temps. And that is why the slope & intercept found when you use 50 and 150 as the end points is so bad halfway between those points. The real curve is a long way below the linear curve which just zips straight between the end points, like this one. You could probably use the same slope and a lower intercept, to move that straight line down, and spread the error out. But you would 5-10°C off in a lot of places. You'd need to say what temperature range you really wanted to be most right - say, 100 to 130, and plop the line closest to teh real curve in that region, which would make it quite wrong down at the lower temperatures. Let me just say that HPTuners are not being realistic in only allowing for a simple linear curve.
    • I feel I should re-iterate. The above picture is the only option available in the software and the blurb from HP Tuners I quoted earlier is the only way to add data to it and that's the description they offer as to how to figure it out. The only fields available is the blank box after (Input/ ) and the box right before = Output. Those are the only numbers that can be entered.
    • No, your formula is arse backwards. Mine is totally different to yours, and is the one I said was bang on at 50 and 150. I'll put your data into Excel (actually it already is, chart it and fit a linear fit to it, aiming to make it evenly wrong across the whole span. But not now. Other things to do first.
    • God damnit. The only option I actually have in the software is the one that is screenshotted. I am glad that I at least got it right... for those two points. Would it actually change anything if I chose/used 80C and 120C as the two points instead? My brain wants to imagine the formula put into HPtuners would be the same equation, otherwise none of this makes sense to me, unless: 1) The formula you put into VCM Scanner/HPTuners is always linear 2) The two points/input pairs are only arbitrary to choose (as the documentation implies) IF the actual scaling of the sensor is linear. then 3) If the scaling is not linear, the two points you choose matter a great deal, because the formula will draw a line between those two points only.
    • Nah, that is hella wrong. If I do a simple linear between 150°C (0.407v) and 50°C (2.98v) I get the formula Temperature = -38.8651*voltage + 165.8181 It is perfectly correct at 50 and 150, but it is as much as 20° out in the region of 110°C, because the actual data is significantly non-linear there. It is no more than 4° out down at the lowest temperatures, but is is seriously shit almost everywhere. I cannot believe that the instruction is to do a 2 point linear fit. I would say the method I used previously would have to be better.
