I was going to say that it was that speed demon named Shell  :)  but then you said it had a Y in the rego plate.....
Shell - did you change your rego plates for summer nats ?   :headspin:
lol... considering i was in adelaide, it BETTER NOT be my car!!! :P
my car should have been safe n sound at my house, with my neighbours keepin an eye on it... oh hang on :nowigetit
https://www.sau.com.au/forums/topic/30059-spotted/page/6/#findComment-653780
I parked next to a yellow R34 GTT at belco in front of pizza hut, then you followed me down to Ginninderra Dr, i'm sure its the one that parks in dickson. i would have waved except i almost spilt my coke on my crotch, very cold.
https://www.sau.com.au/forums/topic/30059-spotted/page/6/#findComment-654517
is that the one with no rear spolier if so yea that would be him he parks out the back of the transact building everyday
https://www.sau.com.au/forums/topic/30059-spotted/page/6/#findComment-654627
sxygtst you up for lunch next thursday at that place? Ive got my car here today but couldnt make it unfortunately.
amaru next thrsday sounds good. i couldnt make it either. if anyone else is interested let us know :P
https://www.sau.com.au/forums/topic/30059-spotted/page/6/#findComment-656124
spotted on the Saturday of the long weekend - blue R32 coupe flying down the parkway keeping up with some Merc-type thing with a flag on the bonnet (??)... i was doing about 110km and they went past me like i was standing still :Oops:
https://www.sau.com.au/forums/topic/30059-spotted/page/6/#findComment-659984
Just spotted then at the intersection sportsmans warehouse in belconnen, two silver r34's one was a 4 door and the other just a GT-T. I have seen both of these around a bit, anyone on here own them or know who owns them???
Cheers
Yeah Weetbix, I have seen these around the Belco mall a bit. Is the 2-door fairly flash? With rear diffuser and Nismo bodykit? I think the 4 door has chromies, unless there is another goin around like that? I've also seen a White 2 door GTT goin round with GTR 34 bodykit - Very nice!
https://www.sau.com.au/forums/topic/30059-spotted/page/6/#findComment-662774
    • Just as a thought, if it's in neutral, thats your drive line disconnect, not the clutch. Clutch slip at the dyno with pedal fully out, is actually adding a second disconnect. So it's not a clutch issue if you're in neutral. Just a bit of friction dragging the output around while in the air.
    • The HG high flow is excellent, and costs about the $$ you're talking about. But it, and probably every other highflow, uses a diffeent core than the original turo, and the original Hitatchi core is quite long. So, I think it is inevitable that there is likely no such thing as a highflow that just "bolts on" with no other effort required. And the same is likely true for HG's outright replacement "bolt on" turbos (the ATR things). And the same is likely true for anything similar from elsewhere. I have no idea if the cheap Chinese/Taiwanese complete turbos from eBay/Temu/etc are as bolt on as they claim. I mean, they claim the bolt onto the NAs as well as the turbos, and we know that can't be "bolt on". But it wouldn't matter because I'm not buying a $169 4 psi turbo for anything other than a paddock basher.
    • Bummer...yeah i "need" something to "ease" up the work and for my driving it would be enough.    Iam counting the tune "without" turbo. I do not mean "cheap" like something from Temu around 200 USD, "Cheap" is something around 1000 USD?
    • Starter motors used to use the weight of metal (magnets) to provide torque. Now they use (more) current instead. This. It's completely normal.
    • So thing that had me stumped, but I think is OK....is that when it was up in the air, in neutral I had it running to bleed to coolant while I put the wheels back on. I noticed the rears were turning (slowly) which I'd never seen before 20250928_163512.mp4     Because there had been an issue with clutch slip due to pedal adjustment on the dyno, I assumed there was still and issue so spent some quality time upside down under the dash adjusting the pedal....but no matter what I did the wheels still turned in neutral. Even disconnected the master cylinder to pedal rod and same. In despair, I even removed the clutch slave so there was no chance of any preload causing it.....still happened. So either: 1. Something is not right in the bellhousing, or 2. Its a thing sometimes with cold, thick gearbox oil Internet says it might be 2, I hope so!
