Anfanee, I saw you driving into Phillip of Hindmarsh today, maybe around 4.30pm or something? 5pm?
Car is looking nice!
Yeah that was me! the car is filthy! was dropping it into ultimate tunes for its final work.
Also forgot to mention Spotted RS4-S on Athlon Drive turning onto Drakeford i was in the black SS ute next to you haha
https://www.sau.com.au/forums/topic/30059-spotted/page/794/#findComment-6699334
White wingless R34 with white wheels on Barton today 1:10ish. Azathoth???
Maybe at Kippax shops yesterday evening too...
Yeah that was me heading home from work. I tried to wave but my window was half down...it looked pretty special.
There is always a nice S15 with LMGT4's parked in Kippax and a silver 33 that seems to be permanently parked near the servo.
It's like a big belco nissan party at the place.
Edited by azathoth
https://www.sau.com.au/forums/topic/30059-spotted/page/794/#findComment-6700214
Boom... Hat-trick !!!
Mrs Had a Black GTR blow alot of black smoke in her grill on Belco Way while dragging an SS Commo.
Car behing the Commo had yobbos filming the proceedings.
Edited by Not a Pulsar
https://www.sau.com.au/forums/topic/30059-spotted/page/794/#findComment-6700727
spotted a white RS4 stag today around parliament house (not local...forgot the road name), and a nice standard gunmetal R32 GTR heading off Hindmarsh yesterday arvo.
QLD boy here in a white 33 with black GTR wheels. (see sig)
you guys and girls up to anything in the next week and a half? I'll be in Canberra till next weekend and keen to meet a few peeps :)
https://www.sau.com.au/forums/topic/30059-spotted/page/794/#findComment-6700926
    • Bummer...yeah i "need" something to "ease" up the work and for my driving it would be enough.    Iam counting the tune "without" turbo. I do not mean "cheap" like something from Temu around 200 USD, "Cheap" is something around 1000 USD?
    • Starter motors used to use the weight of metal (magnets) to provide torque. Now they use (more) current instead. This. It's completely normal.
    • So thing that had me stumped, but I think is OK....is that when it was up in the air, in neutral I had it running to bleed to coolant while I put the wheels back on. I noticed the rears were turning (slowly) which I'd never seen before 20250928_163512.mp4     Because there had been an issue with clutch slip due to pedal adjustment on the dyno, I assumed there was still and issue so spent some quality time upside down under the dash adjusting the pedal....but no matter what I did the wheels still turned in neutral. Even disconnected the master cylinder to pedal rod and same. In despair, I even removed the clutch slave so there was no chance of any preload causing it.....still happened. So either: 1. Something is not right in the bellhousing, or 2. Its a thing sometimes with cold, thick gearbox oil Internet says it might be 2, I hope so!
    • OK, few more things sorted and it is ready for a shakedown on 10-Oct, with one weird thing. Changed the run in oil and filter for the good stuff. 8l came out, about 8.5 went in with filter so that looks all good. Changed the starter (again), this time for a brand new one, works good. Interesting that the Taaaarks one is shorter than factory but spins harder, I guess electronics have moved on a little in the last 30 years. Will be nice to have a bit of extra space under there. Put the timing cover back on, and noted where the cam gears were set as a record.  Will need to double check the timing but it is pretty close. Also put the coil pack cover and intake snorkel back on. Exhaust Inlet Changed the water out for coolant, bled up nicely. Removed the rear brake pads (well worn factory sumitomo ones!), gave the hardware a good clean and reassembled. I've put bendix XP on the back again because the price is excellent at $150 a set and they worked well on the V37. Front pads have plenty so no issue there
