Spotted this pearlescent r33 in the canberra hospital carpark today. Looked like a bit of a bomb apart from the paint job and the rims. 10 bucks no one else has seen it though seeing as everyone is northside.. :mellow:
https://www.sau.com.au/forums/topic/30059-spotted/page/840/#findComment-6877745
If it's the green/gold/purple pearlescent R33, my understanding is that it's running an LS2 (6.0L V8) and can run 10s....though I swear the few times I've heard it running it definitely wasn't a V8 lol
https://www.sau.com.au/forums/topic/30059-spotted/page/840/#findComment-6878456
Given up officially spotting Jimmy who doesn't notice me even with flashing lights and whatever I can do to grab attention LOL!
Think I spotted RIchard in the GTR going opposite way to me on GDE or the parkway this morning.
Parked opposite a black stag with for sale sign on the back this morning too.
https://www.sau.com.au/forums/topic/30059-spotted/page/840/#findComment-6878471
Wow, guess I'll have to keep my ear out then..
https://www.sau.com.au/forums/topic/30059-spotted/page/840/#findComment-6879154
Let me correct you on this one budd. I own this car. It is running a nitrous Ls2 with a tricked up auto and lock diff. It has never seen the strip in this configuration so the times you mentioned are false. The car is not a show car, It gets driven daily hence its not always clean. The front bar lets the car down, but the rest of the car is clean.
https://www.sau.com.au/forums/topic/30059-spotted/page/840/#findComment-6881047
    • So for the wide band is a Bosch 4.9 correct for the Link G4+ along with a Can bus? Just get the Link gear or is generic ok too? Eg here: LINK LINK DIGITAL WIDEBAND CAN MODULE WITH BOSCH 4.9 SENSOR : KYP Performance House
    • Bit difficult to follow. Have a look below and see what the standard R32 layout was like. Note there was a restrictor in place immediately before "turbocharged pressure control solenoid" that, if removed, magically got you 1 bar boost.
    • I might be way off the mark here.. there must be a T junction under the manifold. That takes manifold pressure through a check valve prior to the T, one side splits out to this bleed off orifice, the other straight to the wastegate actuators.
    • Carrying out some engine due diligence before my first drive in a 260RS that has been in storage for 10+ years, and found two lines that are susposed to be plumbed into the boost control solenoid. One of the lines (the wastegate boost supply line) to actuate the gates, had a bolt in one end blocking it. The other line (main boost signal line) from the very rear of the intake manifold (RB26DETT) and runs up to the boost controller had this pill in the end of it as seen in photos. Other than the obvious (T28 Ceramic turbos might well be cooked)  Can anyone shed any light on if there is any validity at all with this mod, bleeding a constant fixed rate of manifold boost pressure off through this 3mm hole?  Is it deliberate?  Was this a 90s Jap mod done to RB26's? Or has someone just fitted this without any idea of what happens to ceramic T28s if they are not gate controlled?
