Let me correct you on this one budd. I own this car. It is running a nitrous Ls2 with a tricked up auto and lock diff. It has never seen the strip in this configuration so the times you mentioned are false. The car is not a show car, It gets driven daily hence its not always clean. The front bar lets the car down, but the rest of the car is clean.
Not having a go at you budd, just giving you the facts. :)
https://www.sau.com.au/forums/topic/30059-spotted/page/841/#findComment-6881087
Ahh ok, yeah I wasn't so sure on the strip times as I can't even recall where I heard that lol, but good to see I'm not completely insane and was at least right about the engine ;) Also good to see the owner is at least a member on here :) I quite like it myself, though I'm not really a fan of the pearlescent paint - as awesome as it does look, just not my thing.
Yeah Trozzle - You should've known bud ! GOSH !
SIR. MY f**kING BALLS. YOU ARE BREAKING THEM. LOL
:cheers:
  • Like 1
https://www.sau.com.au/forums/topic/30059-spotted/page/841/#findComment-6881332
your a shart stirrer buddy
Did you T-Bone him and ask "WHERE DA KEYS FOR THE STOLEN GOODS AT?"?
(He probably waved to say "You're next". LOLOL)
Fairly sure it must have been Vera
Edited by Sinista32
https://www.sau.com.au/forums/topic/30059-spotted/page/841/#findComment-6881380
Was me Richard. You may have noticed this time I was giving my mother a lift in the skykine, she dropped my grandmothers car off for a service.
You were driving a little fast dont ya think?
I've had my eyes on your 34 since you got it. Reds a nice colour.
https://www.sau.com.au/forums/topic/30059-spotted/page/841/#findComment-6881420
LOL :D !
Please sir, anything, I'll give you anything ! Not Rosie !
https://www.sau.com.au/forums/topic/30059-spotted/page/841/#findComment-6881479
I'd just got up (still asleep really) to take son to work. Wasn't really with it.
34 was warming up so couldn't go fast - as I wanted too :(
Don't do what I do coz not a good example :unsure:
https://www.sau.com.au/forums/topic/30059-spotted/page/841/#findComment-6881502
As per the bolded text.
When do I know that the car is ready to be opened/ warmed? I've been looking at the heat gauge (Bottom right) and waiting for it to go to it's normal spot (Just under halfway) however, I have 3 gauges in the middle. (One is turbz and the other is battery volt.) but the other one (Middle) is oil tempeture(?) - do I go off this to know that the car is warmed up? - it sits on 70 for quite awhile.
https://www.sau.com.au/forums/topic/30059-spotted/page/841/#findComment-6881513
Just drive conservatively until the car's at operating temp (temp gauge ~halfway or so), then drive as hard as you want lol.
I'd say once the oil temp is above 50 deg you're fine to drive it however you want really, but that's not a professional opinion :)
https://www.sau.com.au/forums/topic/30059-spotted/page/841/#findComment-6881526
Water temp is a terrible gauge to tell if the car is ready to drive hard. If that's all you have keep going easy for a few minutes after it reaches normal temp.
If you have oil pressure, notice how high it is when cold, and how low it is after a long drive. When it comes down from high/cold to low/normal it is ready to hoon.
If you have oil temp, anything over about 60- 70 is ready like trouble said
The important thing is it might take much longer than you'd guess to warm up, esp on a Canberra morning. The stag is not getting anything near warm on my commute.
Dont thrash a cold engine! It is way bad for it!
https://www.sau.com.au/forums/topic/30059-spotted/page/841/#findComment-6881540
And don't shut down an engine that isn't at operating temp after a short drive :P if the oil isn't hot enough, the little bit of fuel that slips past the rings etc won't evaporate and in turn will sit in the oil and ruin it.
https://www.sau.com.au/forums/topic/30059-spotted/page/841/#findComment-6881544
Cheers guys !
Yeah - I tend tp not thrash the car (if at all) but I don't use my Turbz until maybe 10-15 minutes into the drive and after that I wait until all gauges are lifted from the bottom of the gauge. I do wait 2mins or so (idle) of a morning and have a turbo timer set to 30seconds but will sit with the car running for 30-60 seconds before the 30 sec timer engages. I just thought I'd use the gaugges instead of them looking pretty haha
The middle gauge sits on 70 from cold and I wait until 85'ish? (it won't go any higher).
https://www.sau.com.au/forums/topic/30059-spotted/page/841/#findComment-6881582
Should sit on the needle below 70.
When it raises to 70 then it's go time
Should be capable of going over 85 tho ?
Edit: Can drive after a minute or so from cold. Stay off boost till oil is warm enough.
Edited by Sinista32
https://www.sau.com.au/forums/topic/30059-spotted/page/841/#findComment-6881614
I don't thrash mine, but I don't let it idle too long or baby it either. I don't take it to redline or launch as it's not just the engine that takes time to warm up. I certainly get it on boost (under load) before the oil is 70+ and water temp is at 'normal'. won't hurt them to be driven realistically!
https://www.sau.com.au/forums/topic/30059-spotted/page/841/#findComment-6881628
Thanks for that Richard. Very Cool. :cool:
Temps? My oil Temp was getting up around 95 on my work commute a few weeks ago... Doesn't get much over 70 now. Ambient Temps affect things more than you think.
I don't sit idling on cold start but I change gear no higher than 3000rpm til over 70 on oil temp. Well, a combo of oil pressure and temp.
Need to hook up my water temp gauge properly for more information. Just can't be stuffed cutting Radiator hose etc... :)
https://www.sau.com.au/forums/topic/30059-spotted/page/841/#findComment-6882101
Spotted RS4 or whatever your username is at your place of employment in Fyshwick ;)
Also spotted the person that has the dark blue 300ZX on Gladestone Street about 4pm.
And a silver R33 GTR at Dan's Tuggers. Guy was wearing HI VIZ.
https://www.sau.com.au/forums/topic/30059-spotted/page/841/#findComment-6882153
Spotted RS4-S...
I'm wearing that exact outfit right now. :yes:
Pshhh. I do burnouts on my driveway when cold. Im that loose.
Tru Dat. You gotta see a Gynecologist cooz yous a loose Carnt hey Bro. :D
https://www.sau.com.au/forums/topic/30059-spotted/page/841/#findComment-6882156
    • Seat of the pants assessment of the new intake: The car is way less "doughy" when hitting the loud pedal, especially off idle when stopped or in traffic, I did use a cheapo lazer thermal thingo to measure the temp around where the pod filter got its air, it was between 55 - 60°C, in saying this the car was shut off and not moving, so the OEM intake pipe was not supplying any fresh air to where the pod was when the car was at least moving A weird bonus was induction noise on the throttle in the cabin increased a bit,  I was worried that I was actually going to lose some of that induction noise I love so much, outside though, when I got the daughter to do a WOT drive by pass for me, the induction noise has increased alot when on the throttle, not quite ITB doort, but well up there I'm extremely happy with the results and have been exploring the country roads in the region  As for house mods: 1.New front fence is up and is awesome, it really upgraded how the joint looks from the street, and the added security is nice 2. Electricians have replace some interior lights, and with more lighting in the garage, a few new motion detecting lights out the front above the garage, front room, and at the front door, which I have already found heaps helpful coming and going, also now has fancy pants CCTV all round the house The only hold point for power though is the solar and batteries due to supply issues, although this will happen over the next few weeks 3. I have done a heap of landscaping out the front and I'm almost ready to do a new small retaining wall with some nice blocks to replace the brick and cemented in rocks around the raised garden beds cemented in river stone "was the fashion at the time" the house was built. I currently have a pallet of retaining wall blocks and 2 bulka bags of 20mm blue metal to replace the wood chip that is in the raised garden beds around the house 4. I now have 3 big raised garden beds for out the back to grow some vegetables, about 70cm high, 200cm long and 100cm wide 5. My 2 compost bins are already pretty full with brown, green and kitchen waste from the landscaping I'vedone so far, but they will probably take a few months to break down, so anything else that gets chopped, trimmed, and kitchen waste will just start filling the base of the raised garden beds to about 30cm before I start throwing 40cm of good compost, and stuff, for the vegetables to grow in, I'll need a few ton of compost and soil, but the local supplier can sent me bulka bags of the stuff Basically the logs, wood chips and a few strategically placed rocks for drainage, will give the beds some good organic materials down low to break down over time, and they will hold moisture during the warmer months to save the water in my big arse water tank if we don't get alot of rain So, all in all, the car and house mods are going well, and I'm really enjoying being retired, I sleep in too 0700 and slowly plod around inside until I feel like actually doing anything, and only work in the yard for as long as want, which has actually been alot over the last few weeks,  although when you look at it, it seems that not a huge amount of work has been done,  until I look at the before I started the work pics Happy days and good times indeed
    • hahaha yeah. Plan is to get side skirts and probably just rear pods. But going to do them one-by-one. I've got a set that I really like from RHDJapen, but that one isn't shipped to AU. So need to find someone who can get it for me
    • Here's an idea, answer the questions I asked you as they are trying to work out WHY the LSD will be binding up in a straight line.
    • You haven't driven many modern cars then have you? Most of them have sfa steering feel with their stupid electric bullshit steering systems.
