Out walking the Doggie, Spotted and Waved to 5hiv's Bro (silver 34) about 10 minutes ago...
Must have been me driving as i was using his car whole day but i didnt saw you, sorry.
Black 33 (maybe GTR)? with Black rims cruised past my place about 10 mins ago...
Its my mates car, Black R33 with Black rims and has a GTR spoiler. He was at my place as i was putting his Spoiler on. Love to work on Skylines :)
https://www.sau.com.au/forums/topic/30059-spotted/page/853/#findComment-6927474
White 33 GTR on London circuit this morning, saw it leave and park in the carpark across from Rydges.
Also saw a black R35 gunning it along the big roundabout.
Stop teasing me with GTRs while I'm stuck in the office!
white one sounds like the same I saw earlier today. occasionally see a nice Aston out the back of my building (Customs house)
https://www.sau.com.au/forums/topic/30059-spotted/page/853/#findComment-6928587
Yep spotted a white 33 gtst with a gtr wing this morning (outside Allara hse)
I was at mingle when I saw it at the lights. can confirm it had GTR wing and wheels
I didn't look closely, I was actually up in my office and it was down in the carpark. Had a GTR badge etc, looked whale like enough.... :)
couldn't see the entire car, but I agree, it looked to be a GTR
https://www.sau.com.au/forums/topic/30059-spotted/page/853/#findComment-6929814
Yeah that would have been me in the white GTR. Can confirm it's not a GTST :) Been a while since I've been spotted :D
https://www.sau.com.au/forums/topic/30059-spotted/page/853/#findComment-6931022
    • Working through possible solutions of converting my mechanical speedo.    Anyone know what type of speedo sensor the factory r34 gtr getrag has ? what the output is ? I assume its not a VSS and more a voltage like earlier speedo sensors ? Can an ECU read it ?
    • roof rail delete used to be a thing, they were made locally for a while too
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
