Spotted a poor bastard in an r33 white with black wheels at the side of the road in the rain with a mate looking under the bonnet of the car. Looks like someone broke down at the side of the road! Whoever it was hope it wasn't too bad
https://www.sau.com.au/forums/topic/30059-spotted/page/855/#findComment-6938700
Spotted a black Stag with green wheel at about 1735 turning off Athlon onto Drakeford in Tuggers.
Gave a wave as he went by but not sure if he saw.
Woo spotted. Nice GTR mate, missus was jelly! Was gunning past trying to get thru the green arrow so didn't get a chance to wave back soz.
https://www.sau.com.au/forums/topic/30059-spotted/page/855/#findComment-6939228
Spotted Blue Hyundia Velocitor with P plates on my street around midday
Don't know what said numnuts had done but it warranted no less than 3 pursuit cars with lights F L A S H I N G
He looked not impressed siting on gutter with head in hands - LOLZ
https://www.sau.com.au/forums/topic/30059-spotted/page/855/#findComment-6941658
    • So for the wide band is a Bosch 4.9 correct for the Link G4+ along with a Can bus? Just get the Link gear or is generic ok too? Eg here: LINK LINK DIGITAL WIDEBAND CAN MODULE WITH BOSCH 4.9 SENSOR : KYP Performance House
    • Bit difficult to follow. Have a look below and see what the standard R32 layout was like. Note there was a restrictor in place immediately before "turbocharged pressure control solenoid" that, if removed, magically got you 1 bar boost.
    • I might be way off the mark here.. there must be a T junction under the manifold. That takes manifold pressure through a check valve prior to the T, one side splits out to this bleed off orifice, the other straight to the wastegate actuators.
    • Carrying out some engine due diligence before my first drive in a 260RS that has been in storage for 10+ years, and found two lines that are susposed to be plumbed into the boost control solenoid. One of the lines (the wastegate boost supply line) to actuate the gates, had a bolt in one end blocking it. The other line (main boost signal line) from the very rear of the intake manifold (RB26DETT) and runs up to the boost controller had this pill in the end of it as seen in photos. Other than the obvious (T28 Ceramic turbos might well be cooked)  Can anyone shed any light on if there is any validity at all with this mod, bleeding a constant fixed rate of manifold boost pressure off through this 3mm hole?  Is it deliberate?  Was this a 90s Jap mod done to RB26's? Or has someone just fitted this without any idea of what happens to ceramic T28s if they are not gate controlled?
