Fight you for the corner blondie!
Business is business, if you pick some up on the corner, then good for you. :P
Shell got the car back for real??? I can feel a Cruise coming on. :woot:
Spotted this today at work. It demanded *Giggles*.
https://www.sau.com.au/forums/topic/30059-spotted/page/859/#findComment-6949330
Yes, I was thinking in 3 weeks. I'm busy for the next two and it gives people plenty of notice.
We'll work on that then. :)
Maybe some extra cruisey fun in the meantime...
CLAM FLANGE!!!! *giggles* :rofl:
https://www.sau.com.au/forums/topic/30059-spotted/page/859/#findComment-6949368
Yeah I also spotted the shitbox skyline yesterday arvo at the lights from Belconnen way onto GDE - I pulled up next to it. I would've waved, but firstly it was FJ's missus driving, and secondly I was on the bike lol
https://www.sau.com.au/forums/topic/30059-spotted/page/859/#findComment-6952757
Yeps, tokyo taxi going a little lower with new shoes :)
got new highflow turbs on yesterday (old OP6 had a seizure)
Dr Rob and nurse Jeremy watched it die with me last weekend....
Thought it was yours but only saw the tail. White 33 there also with drift toy hanging of the tow hook.
Your car looks awesome Tom - Swaps this arvo ??
https://www.sau.com.au/forums/topic/30059-spotted/page/859/#findComment-6952969
Sup. My contribution were duly noted. "Is the Actuator on backwards?" LOLOLOL I know my cars.
Edited by RosieR34
https://www.sau.com.au/forums/topic/30059-spotted/page/859/#findComment-6953001
    • Ha, I've never pressed the X in all these years incase it removed the notification for all Admins
    • I don't know, I've never done it that way, but 1. While it is an interference engine, there is still clearance between the valves and the piston at all points in the regular timing cycle 2. There is not a lot of distance before you can't catch the top of the valve stem any more I don't know if 2 is greater or less than 1. But 3. If it doesn't work out you are f**ked, engine is coming out to disassemble so it is a big bet.
    • Semi slicks are horrible for road use, just use a high performance road tyre unless you really need the maximum grip. Noisy, unpredictable (amazing, until they are not), expensive due to very high wear and not good in cold and particular wet. And yes, it is a thing to store cars on stands instead of tyres if you know they are going to be parked up long term.....but who ever realises that a short park is going to stretch into years before it is out again!
    • I know in Australia you'll definitely get above 30c. Parked in the shade in Summer you'll be above that. 😛 But in cooler climates, you might get that warm driving on the highway for a bit, but you'd never get to full heat temp. I'll try and find some of my historical tyre temps between Aus summer and winter (be aware immin the warmer area of Aus too.)
    • I get that taking off the head is best but that's a bit much for "just" valve seals. I was just under the impression that one would be able to rotate to TDC and be able to temporarily drop the valve without losing it and effectively having to remove the head to then recover it. I never knew people actually pushed rope into the cylinder to do valve seals hahaha So just to confirm, just going to TDC will not work? In that case I know when I do valve seals I'll maybe just remove the head and do some other things while I'm there, or just wait until I do an engine build.
