Meh... :unsure:
I know Scar has a Chaser. Chunkier than a Soarer but yeah...
Eternal n00b. :rolleyes:
ah rob, you have much to learn about toyota's :P
http://carphotos.cardomain.com/ride_images/3/2769/4521/31922260005_large.jpg?v=0 <- Stock Series 1 JZX100 Chaser (Mines a series 2 with vertex kit)
http://img802.imageshack.us/img802/9049/nakw.jpg <- JZZ30 soarer (which shares the same chassis as a supra)
Seen plenty of skylines around as usual..
https://www.sau.com.au/forums/topic/30059-spotted/page/930/#findComment-7221186
