All spotted today at Auto Italia.
White R35 GTR, white R32 GTR with bronze wheels and a Midnight Purple R33 GTR with dark rims that had a red stripe around them.
Spotted all of them up near old parliment house.
Had a chat with the guy who owned the 33 GTR, it's been tuned by trojan and makes 300+kw
Got photos of it's engine bay and it looked shmick
https://www.sau.com.au/forums/topic/30059-spotted/page/933/#findComment-7243812
why you not lying down in the bath tub or over a plastic drop sheet ?
Sorry I missed seeing you, was eye's firmly on the road ahead. Have to make all the lights along that stretch.
Yeah you were near the Good Guys. Pity you didn't spot me - that was Banana car's final drive. She's gone now :(
https://www.sau.com.au/forums/topic/30059-spotted/page/933/#findComment-7246077
    • Ok thanks..that was my second question if i can somehow bypass this even with Nistune(that is all i have right now...aparat from stock ECU. So with some aftemarket it can by "bypassed" or make it work?  I know there is Link or Haltech (mainly used). We have ECUmaster here so i will gather some info about it.
    • Yes. You will need to get the original boost sensor and wire it in. That is.... if you plan to use a stock ECU - even a Nistuned ECU. The Nissan ECU will not operate correctly without it connected. And yes, it will do annoying stuff like you are experiencing. You will almost certainly be better off with some aftermarket ECU, than trying to hunt down rare sensors.
    • Ok so ABS/TCS is "not" the problem. Yeah i know now about the ABS with Nistune(i told that to the Nistune guy) but iam not 100% why or why i dont have ABS. ABS cube is in the engine (always has been) but i had braked couple of times rly hard and brakes just locked and scream. Does all Skylines have ABS cube? That boost sensor https://www.sau.com.au/forums/topic/367633-wtb-r34-gtt-turbo-pressure-sensor-pics-inside/ Is this it? I need to ask but i have a picture of engine bay and i do not see that (100% is not in that place) If i do not have this the car can do what mine is?(cutting around 4000 rpm) Here is the pic of my engine bay(only one i have) BUT i think i dont have that cuz loom was used from my RB20DE NEO and i know (obviously) that it does not have boost control or any wire to that...) so maybe that is the problem? (i dont know for 100% if that car where the engine is from had that)...but i dont have the loom from that
    • I'm with you here. It's either loom has an issue, OR, injectors are not functioning properly. It could even be they're just constantly dribbling, hence the wet, but not firing.
    • Depending on how long the car sat it is very possible for injectors to be stuck open or closed, I'd get them cleaned and flow tested. Other than that, obviously when the loom changes and the car doesn't start any more....the loom is suspect so some tracing / comparing may be required
