Haha don't knock the daily work horses!!
Although, the X5 is going to look at LOT better with a GTR on the back which is why we bought it! :D
Yeah thats fair enough I guess.
I'll keep an eye out for it.
https://www.sau.com.au/forums/topic/30059-spotted/page/943/#findComment-7322957
Ours is not an under $20k version.
We did look at the Range Rover sport and were tossing up between both cars but at the end of the day the service at BMW vs the service when we looked at the Rangie (forget the exact dealership name but the one at Woden) made the decision really easy for us.
And yeah all depends what your needs are. We just need to tow a trailer which is 500kg and the GTR which is 1554kgs so more than does what we need it for.
https://www.sau.com.au/forums/topic/30059-spotted/page/943/#findComment-7323175
did you go for the turbo diesel?
https://www.sau.com.au/forums/topic/30059-spotted/page/943/#findComment-7323324
Cruised behind a Matte Black 180sx along Southern Cross Drive around 3:30pm.
Was so low and hard in the rear, it seemed to be bouncing and skipping around everywhere.
Looked like it would be pretty hard to drive in the wet I reckon.
https://www.sau.com.au/forums/topic/30059-spotted/page/943/#findComment-7324103
The 34 Anthony. New bonnet is fitted & sprayed and will pick-up tomoz after buffy :woot:
then I'll detail the inside
also having the front/rear bars done on 32 4 door. I'm not happy with a few scratch marks on them :(
34 out & 32 in
:yes:
Shaun, be careful reversing around there please :P
https://www.sau.com.au/forums/topic/30059-spotted/page/943/#findComment-7328082
    • They are, a good friend of mine bought one to replace his blow factory turbo, running a Toshi Tune reflash. Just use their supplied water/oil lines and you're good to go. At the time, they were like $900 delivered.
    • This is an option for 100% bolt on, the GCG high flow -  https://gcg.com.au/turbo-charger-upgrade-skyline-gtst-2iu-xtrgts-s1.html Also, I'm pretty sure hypergear does a high flow that is 100% bolt on, it just doesn't make as much power as their bigger high flows.  Even if you get a hypergear turbo that requires you to chance the intake piping, it is a really simple modification. It can be as simple as a piece of silicon hose and you pop a filter on the end. It doesn't have to be some crazy pie cut titanium work of art intake pipe.  If you have the ability to swap the turbo yourself, you would be able to sort the intake piping out.
    • Just as a thought, if it's in neutral, thats your drive line disconnect, not the clutch. Clutch slip at the dyno with pedal fully out, is actually adding a second disconnect. So it's not a clutch issue if you're in neutral. Just a bit of friction dragging the output around while in the air.
    • The HG high flow is excellent, and costs about the $$ you're talking about. But it, and probably every other highflow, uses a diffeent core than the original turo, and the original Hitatchi core is quite long. So, I think it is inevitable that there is likely no such thing as a highflow that just "bolts on" with no other effort required. And the same is likely true for HG's outright replacement "bolt on" turbos (the ATR things). And the same is likely true for anything similar from elsewhere. I have no idea if the cheap Chinese/Taiwanese complete turbos from eBay/Temu/etc are as bolt on as they claim. I mean, they claim the bolt onto the NAs as well as the turbos, and we know that can't be "bolt on". But it wouldn't matter because I'm not buying a $169 4 psi turbo for anything other than a paddock basher.
    • Bummer...yeah i "need" something to "ease" up the work and for my driving it would be enough.    Iam counting the tune "without" turbo. I do not mean "cheap" like something from Temu around 200 USD, "Cheap" is something around 1000 USD?
