I'd just walked out of mingle with my morning coffee, both times I've seen you has been on foot. Looks tidy BTW.
Thanks mate. Not quite as tidy as I would like at the moment (needs a good bit of clay bar action - hopefully this weekend).
Whereabouts you work?
https://www.sau.com.au/forums/topic/30059-spotted/page/952/#findComment-7370618
Spotted 'the34t' today driving on Cooma St QBN.
I was the fat bloke on a CT110 in fluro going Nnnniiiiiirrrrrrreeeeeeeeeeee flat out the other way.
Needless to say I didn't wave as I was full aero.
Was that near the school? ..... I usually take note of CT110's, sorry mate, but I think I do recall you passing by. In any case nice to meet you :action-smiley-069:
https://www.sau.com.au/forums/topic/30059-spotted/page/952/#findComment-7376192
Yep, I was heading south. Car looked good. Sounded like Nnnnnnnnnnniiiiiiiiiirrrree :woot: haha.
Edit: Also, how do the posties do it all day? I spend about 3 hrs on that stupid gutless bike doing my own LBD's and I'm ready to throw it in the river!
https://www.sau.com.au/forums/topic/30059-spotted/page/952/#findComment-7376196
    • Hi...so a "development" here aswell The swap is "done" and car went "test drive" BUT it seems the clutch(maybe gearbox?) is a little bit sad? I bought this clutch kit https://justjap.com/products/xtreme-heavy-duty-organic-clutch-flywheel-kit-nissan-skyline-r31-r32-r33-push-type "Problem" is that the first gear is hard to put into and it seems that the clutch is not disengaged. It was not the problem with the old clutch...(or like sometime the first gear would not get as easy specialy when the fluid was cold) So? Can it be like...bad "install" or is the clutch wrong ((it should not have been) i done research to get the right one) Or is this "normal" with new clutch and needs to be break in?
    • @Duncan I can try  and thanks i did not thought about VIN and part numbers for 33/34. @GTSBoy yeah it looks like iam gonna do that
    • Forgot to include this but this is the mid section of my steering rack that looks like it has a thread/can be turned with that notch mentioned in the post:
    • Hey everyone, Wanted to pick some brains about this issue I'm having with rebuilding my 33 rack (PN is 49001-19U05). All of the tutorials/videos I've seen online are either R34 or S Chassis racks which seem to be pretty straightforward to disassemble but this process doesnt carry over to my rack. Few of the key differences that I've noted The pinion shaft on the other racks bolt on with 3 torx bolts: Whereas my rack bolts on with 2 allen head bolts: These changes are pretty inconsequential but the main difference is how you pull the actual rack out of the housing. The other skyline/s chassis racks can be taken out by tapping the rack out of the body with a socket and it just slides right out. I'm unable to do that with my rack because there's a hard stop at the end that doesn't let the seal/shaft be tapped out. Can also see a difference in the other end of the rack where mine has a notch that looks like you're able to use a big wrench to unthread 2 halves of the rack whereas the other racks are just kinda set in with a punch. My rack: Other racks: TLDR; Wanted to know if anyone has rebuilt this specific model of steering rack for the R33 and if there were any steps to getting it done easier or if I should just give this to a professional to get done. Sorry if this post is a bit messy, first one I've done.
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
