Saw a Silver series II R33 GTS-T just after the roundabout outside the southo Woden. He (or she) was turning right into the canberra college road.
I'll say it now, there is nothing sexier than skyline lights lit up in the mid afternoon, when the sun is just setting. better then the car is a clean silver. hmmmm
i really can't wait to get a 'line, another 3 years atleast :S
https://www.sau.com.au/forums/topic/30059-spotted/page/17/#findComment-766502
a white 33 went past me on belco way just past caswell dr at about 4:45, then as i was turning into haydon dr i saw a nice red 31 with a fmic across the way.
Whoa!!! might finally have been spotted (white R33). This is about the time I was heading home yesterday arv - though don't remember seeing any 'lines near Caswell / Belco Way... I was have a little bit of fun with a blue SS at the time though :):rofl:
https://www.sau.com.au/forums/topic/30059-spotted/page/17/#findComment-769001
Whoa!!! might finally have been spotted (white R33). This is about the time I was heading home yesterday arv - though don't remember seeing any 'lines near Caswell / Belco Way... I was have a little bit of fun with a blue SS at the time though :D  :D
i was in front of you then i went into the turning lane. my car doesn't look like a skyline at the moment, more a dustball on wheels.
https://www.sau.com.au/forums/topic/30059-spotted/page/17/#findComment-771966
G'day Weetbix,
That would've been a mate James.  I don't think he parks there anymore...
J
Damn, it was good to see a decent car in the carpark for a change, way too many riced up lancers that park there.
You wouldnt happen to know who parks a Silver R33 GTS-T Ser2 there aswell would you??
Cheers
https://www.sau.com.au/forums/topic/30059-spotted/page/17/#findComment-775247
Cheers
Naa, not sure who owns the series 2.. There's sooo many skyline owners in Canberra that don't know about SAU :D
J
https://www.sau.com.au/forums/topic/30059-spotted/page/17/#findComment-775553
i spotted a very nice greeny colour S2 R33 GTS-Tone of the best looking ones i have ever seen in person... the colour is not my favourite dont get me wrong their but in terms of an overall package it looks sweet body is still stock as eg S2 front bar and spoiler etc but it has a nice big ass FMIC in the front bar OMG my pants :D anyways if the guys who owns it on here wants to be nice and let me have a look up close i would appreciate it as i am looking for a S2 and yours would be a good to have a look over... not to buy though :)
https://www.sau.com.au/forums/topic/30059-spotted/page/17/#findComment-775647
    • I'm with you here. It's either loom has an issue, OR, injectors are not functioning properly. It could even be they're just constantly dribbling, hence the wet, but not firing.
    • Depending on how long the car sat it is very possible for injectors to be stuck open or closed, I'd get them cleaned and flow tested. Other than that, obviously when the loom changes and the car doesn't start any more....the loom is suspect so some tracing / comparing may be required
    • Harness is for a s1 Rb25det, and it is engine and lower harness.  the old harness had broken off plugs and was in very rough condition/exposed wires and splices etc. it is not able to be put back on the car, I could visually inspect to see if they had rewired any pins on the ecu plug. The fuel pump definitly isn’t turning off it’s an external pump and very loud you can hear it. Will look at the other harness tonight, am also going to pull the fuel rail and watch the injectors spray, will update here with what I find. Pretty sure at this point it has to be something to do with injectors because car will fire up on starting fluid and cas is clicking the Injectors. Fuel pressure is steady 43psi
    • Check the injectors flow evenly, and are actually flowing what you and the ECU think they should be flowing. If it's starting up on starter fluid, you have a fuel issue. Is it possible under cranking your fuel pump is turning off?   The harness you replaced, is that the whole engine harness? Do yourself a test, and drop the old harness on and plug it into the Z32 ECU. It's possible they've wired things different. From memory S1 to S2 is different in RB25 and you may have a wrong loom
