At 1:30 today spotted a black 260rs stagea at the carwash. I was guna walk over and say hi but thought I better not play the creep card.
All about 4:45 today.
White 33 GTR with black/carbon bonnet, rear bar cut out for exhaust and wide as wheels
Blue 32/33 (flew past in other direction) with hektik chromies and nsw plates.
White 33 parked opposite tuggers pool.
https://www.sau.com.au/forums/topic/30059-spotted/page/773/#findComment-6619913
6:30pm ish today saw Maroon? R33 with FMIC waiting at the the lights, Clarrie Hermes & Barton HWY intersection.
Yesterday, Blue R33 with GTR style wing and big Chromies heading up Kingsford Smith, turned right into Melba.
Also yesterday, White R34 heading South on the Parkway 6:20pm.
https://www.sau.com.au/forums/topic/30059-spotted/page/773/#findComment-6620013
you should have played the creep card lol!
https://www.sau.com.au/forums/topic/30059-spotted/page/773/#findComment-6620683
Spotted a 34 GTR following me back from Sydney. He stopped when I got fruit and when we got petrol.
Also spotted a white r31 heading back from a track day I guess because it had some spares in the back and a petty drum. That was along the highway on the way back from Sydney as well.
Anyone on here?
https://www.sau.com.au/forums/topic/30059-spotted/page/773/#findComment-6621024
I don't have kids lol
..that u know of.
White 33 black hood in triggers this morning around 745.
Also had the awkward 10 seconds of where myself and another stagea owner were facing each other whilst queued to turn at an intersection. No waves were exchanged.
https://www.sau.com.au/forums/topic/30059-spotted/page/773/#findComment-6624047
    • A few suggestions: Do you have the option of retarding your exhaust cam gear to bring the power band over to the left? VCT would be turned off after you make peak torque, you see the power/torque will decay faster with it left on all the way to the limiter Once VCT is turned off, you'll find the motor will take a bit more timing being ramped in Send its mum, more boost! Of course, depends on your exhaust pressure.
    • Tow a boat... people won't know wtf is going on 🤣
    • I was back on the dyno again yesterday after completely revamping my methanol injection system. I was making 440kw at 19psi. Great, this is more then I was making last summer with my old meth system at that pressure, and I figured it would be smooth sailing up to 30+psi. We continued increasing from there and by 25psi, I had only hit 455kw. Dyno sadly lost utility power at this point and I left. We seemed to be on course to hit the same power wall as last summer (477kw@27psi). This is a built RB25 S1 stroked to a 2.8. Built and ported head with Kelford 272/262 cams. Precision 6466 Turbo. Tuner last year believed the power wall is a mix of RPM limitations (Hydro lifters/Limit set at 7600RPM) and fueling. With my new meth system, we're seeing zero knock now but it still won't go up.  What else can I do at this point? Here's my train of thought.  - It's clear from the dyno graph that I would easily make power to 8500+RPM but I'm limited to 7600RPM. I could risk increasing my limiter, but hydro lifters have me worried. What are my options here besides going NEO head or solid lifter conversion? I'm rocking a 1.05AR turbine on my 6466. Would dropping down to a .84 help shift that power down in anyway? - We're only seeing roughly a 30kw difference at the top end with VCT on or off. Is this normal? I want to confirm VCT is working properly. - Should I look into other cam options?  - Should I just keep increasing boost and see if she wakes up later on? I would expect to hit 600rwkw around 35psi with my 6466.
    • First thought is to use a ram mount (to hold the ipad) + windscreen suction mount. The arms on the ram mount can be as long as you like, should be able to position the ipad pretty well with that setup.
