OK, so time to get ready for the first round of the Sprints next week, thought i better pull thumb out of my bung hole and get a few things done to the R35. I've primarily made an effort to host these pics for the USA guys (who may be a bit aprehensive of playing with their GTR) not to mention pulling bits off / replacing bits etc....
So here we go, let's get some maintenance underway... we need the car up on stands,,, lets get this big bitchola up in the air...
Using trusty "mini-ramps" (thanks Dave) lift the front end...
Once the front end is lifted with the mini-ramps, get your floor jack under the front jack point (right behind the oil train port as per below..
Lift that sucker way up, ready for your stands...
Position your jack stands at the side jack points, left and right (fronts)
You may need to bring the car down slowly to make sure you have the jack stands positioned properly. You want to end up with something like this..
Now with both left and right (front) in the air, get your jack stand positioned under the rear centre jack point (just under the rear transaxle) such:
Lift the GTR up, position the jack stands just like at the front and lower slowly until you have it all positioned correctly on the rear jack points..
You should end up with something like this, ready for some well due maintenance..
I've found this is the best way to go about it, assuming you are doing this in your own garage.
Now.. let the games (and skinned knuckles) begin..
So... moral or the story is, give it a go,, it's just a car after all, and fark the warranty, fark it right in the eye with a blunt dick i say.
(more to follow)
https://www.sau.com.au/forums/topic/303133-my-r35/
  • Replies 71
good to see . nice plate too
got a list of things your doing to it ? or do we have to wait and see
replacing most fluids (pretty hard to get to front diff!), installing new titanium exhaust (*in pic), some new diffuser blades, some carbon fibre intake snorkels, and a few other things. yep there are heaps of covers under there,took my an hour or more to screw around getting them all off, half the battle. pita. the creeper makes things a LOT easier too.
https://www.sau.com.au/forums/topic/303133-my-r35/#findComment-5025171
I'm loving the look of that Exhaust.
BTW those mini-ramps are ingenious. Ive never come across them before. Where abouts can you get them? Ive always used a scissor jack behind the wheel to get it high enough to slip the jack under.
Looks like some pretty good design under there regarding aerodynamics. Must be a pain taking it off to do any work though.
https://www.sau.com.au/forums/topic/303133-my-r35/#findComment-5025495
I think you can buy them at most caravan dealerships (the mini-ramps) believe it or not. Otherwise a block of wood might do instead.
https://www.sau.com.au/forums/topic/303133-my-r35/#findComment-5025510
Wow, you learn something new everyday... Who would have thought a caravan shop would have something that is actually usefull?
Can also get them from ebay too for those (like me) that wouldn't know where to begin looking for your local caravan shop :happy:
https://www.sau.com.au/forums/topic/303133-my-r35/#findComment-5025532
wow good to see someone who is not afraid to give it a go.
also did you start her up without the exhaust??? lol
Good point, but I think they are fine, all I am really worried about is it falling on me whilst working under the car itself (!). It's a good idea to use the floor jack too, under the central jack points (front or rear) if you are working under the car. That way you aren't depending on just one stand/point alone.
https://www.sau.com.au/forums/topic/303133-my-r35/#findComment-5027281
Great to see you having a go doing everything yourself.
Did you have to take the wheels off to put the exhaust on..? :ermm:
Or you doing a brake upgrade as well?
I am doing brakes too so took the wheels off. I think you could do it with the wheels on if you wanted to.
https://www.sau.com.au/forums/topic/303133-my-r35/#findComment-5027588
    • Don't even try to run it on the stock ECU if you're going to have the boost controller bring boost above ~10 psi. I've already told you that. If you use the Nistune ECU, you will need to CAREFULLY read the available documentation for Neo tuning, and read some threads on the Nistune forums, to discover the various things you have to do to prevent the ECU from going bananas when the boost is too high. The is a table associated with th boost sensor that must be modified to prevent it from shitting the bed. This is just one of the things that you will need to do to the tune in Nistune, because the Neo turbo ECU will be expecting to see a number of things (such as the TCS) that are not there, and you have to block the DTCs on those. It is totally not surprising to me that you are having the problems that you are, but the solutions to these problems have been known for >15 years. So just get it done.
    • Hi. Sry iam not a mechanic and iam not at the car atm so i dont know 100% but they told they measure those and even try to change those. AFM they have two. Coils are new a they have my old one too. Plugs too. ECU...we have 25 NEO stock and Nistune 25 NEO.   But i dont know if any one those could be the problem and why/if/what can cause this, Only thing they did not check is fuel...but that walbro 255 is new(like 1,5 years)... That fuel pressure gauge idk...but i let them know Any suggestions?   EDIT: how can they know if it is like you say he ECU pull power when it reaches a specific boost level that is too high? Tha car has boost controler
    • Can you clarify what you mean by boost cut, do you mean it misfires both when under load (driving) and when stationary and out of gear? Or does the ECU pull power when it reaches a specific boost level that is too high (boost control issue)? Does it occur at idle with no throttle? When you say "the ECU is OK", what ECU is it and why do you think it is OK? Have you used the NEO ECU, and if so do you have a MAP sensor attached? Same for the AFM, why do you think it is OK? Do you have any way to put a fuel pressure gauge on it (even just a mechanical one between the fuel filter and fuel rail)?
    • Hi.. Just another problem. So maybe you can help. I(my mechanic) done swap from my RB20DE NEO to RB25DET NEO. Everything is OK but we have a boost cut. Coils/Plugs are ok...AFM is ok. ECU is ok. I have Walbro 255 but it "changed" sound few months ago(you can hear it ouside) you did not hear that when it was new(maybe faulty?) Sooo...what now? What can cause this boost cut? It is even when you standing still...
