  • 1 month later...
  • 3 weeks later...
  • 1 month later...
  • 1 month later...
  • 4 months later...
  • 2 months later...
Rotorua, 1994 R32 4 door. Just dropped a 20det in it this weekend.
With 400,000ks on the clock driving to a skid comp an hour and a half away, witch it completed without fail, and drove home again!! ahh that was a great engine my little 20DE. Ah new one make cool noises :P
  • 2 months later...
Hi all,
new to the forum as well.
Have two RB's;
2000 ER34 GT-t in bayside blue (TV2)
2000 BNR34 GT-R V-Spec in midnight purple iii (LX0)
Selling the GT-t for a steal - was on trademe for ages, but no takers - so the flatmate snaffled it up.
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
