for drift simon.. but im keen on the switch!
i just finished tuning a std R33 (PFC, FMIC and EXHAUST), i put it on the dyno and tuned it, then fitted cams and cam gears (vct removed) and lost no power anywhere (on identical boost), here are the graphs. Lots of Cam gear dialing but it was worth the effort. Next mod turbo.
whats this hks3037 everyone talks about? what is it equal to in the garrett range?
I could ask "How was your sleep"? :/
Equilavent to a genuine 3076 but it slightly different in set up, do a search on 3037 = 56vs60 and 72vs 82 HKS vs Garrett etc etc
Good stuff, i'd prefer to call myself skeptic though, but each to their own. :/
I'm happy knowing that I've highlighted your factually incorrect statement.
Nothing worse than misleading users of this forum with blatantly wrong information and claims... Claims like Hub dynos are in RWKW - which are wrong.
ladies ladies.. the curve is the curve so lets all calm ourselves and dry the tears :/ the dyno is a tuning tool not the be all and end all of how fast the car is, we all know 3071s are faster... :cool:
lol this was one of the current informative GT30 threads but it seems to have gone off track a touch :cool: back to it shall we?
The HKS 3037S usually makes around 300rwkw/20psi, with the larger .73 rear.
Now take less boost, smaller rear.
You can see where this is going i'm sure...
Yep, no where.
56T vs 52T comp wheel. Not a true comparison.
May as well say my 3071 makes 285rwkw and Juggernauts makes 290 odd. both have the same trim gt30 turbine and different comp wheels too.
Compressor maps to show the 'signifigant' difference between the two Dave?
You'd expect there to be one by the wording of your post...
So there is nothing worse than all your posts?
I didn't realise this was about me...
Good to see you're still a fan :rofl:
ask and you shall receive
the following are the comp maps for GT37 series compressors 56T and 52T
based on 90% VE and calculated at 1.4 bar boost from 3000 to 8000rpm in 1000rpm intervals
the best part is, copy those values into the 3071 map :rofl:
I believe these will come in handy later for people wanting to do the research anyhow.
The .73 rear is a specific HKS ex housing that has a T2 sized inlet flange and GT30 outlet http://www.hksusa.com/categories/more.asp?id=1092, whereas Simons using a Garrett .63 T3 4 bolt rear which has a T3 sized inlet flange and GT30 outlet.
So I'm not sure whether it would be correct to say the HKS T2 .73 is actually larger than the Garrett T3 .63.
Edited by juggernaut1
I have no idea what im looking at with those maps? hahahaha
lol each island indicates a turbos efficiency range, the higher the % the more efficient it is..
idealy you would want a turbo that as your motor spools and revs it passes straight thru the centre island of the map. in this case iv picked max boost (i was conservative as the 1.5 results were far too biased to the smaller comp) then plotted at that boost only to show surge or overheating.
if you cross the edge of the map to the left side the compressor surges, if you cross the right side it starts pumping hot air. both are bad.
Apart from the annoying Garrett scaling... very very interesting Scott.
I can see why when you go the next compressor up how the surging comes about given the 56T is on the borderline :)
Also interesting that the 52T would be fairly well off the map in most scenario's upper RPM's and should fall off...
They are both more or less very similar until upwards of ~7,000rpm
Yet once on the cars it doesn't seem to be the case at all if they make/hold power till 8k without a problem (in the 52t scenario)
That's always made me wonder about some of the maps, never got my head around that part for some reason hehe...
http://forums.bimmerforums.com/forum/showthread.php?t=258035
That should help you a bit, it's a little bit "simpler" than the Garrett site if you are wanting a basic/quick run down of whats going on without serious number crunching.
Garrett site is better overall, but you will have to read it a couple of times and think about it :rofl:
Those trims are not exactly comparable (but gives some insight) ..as the 56 trim has a .6 a/r housing and the 52 trim has a .54 a/r.
So you'd expect the 52 trim to flow more in a .6 a/r comp - which incidently are available through GCG. Also the port shrouded 52 trim .6 flows more than the non-port shrouded comp (440 vs 450) according to the HKS specs.
    • Pressure when IDLING, is meant to be 51PSi... So that amperage value needs to go up a fair chunk... I'd personally be factoring for more like 12amp at least on those runs, and at that point you need to hope the already there wiring doesn't drop you a volt or two, as that's a lot of fuel pressure flow drop off from 13.5 to 12V! Taking idle pressure of 51psi, means the pump will be drawing a MINIMUM of 9amps all the time based on your reading of the graph (3bar base, then allowing an extra 0.5bar for boost = roughly 51psi)
    • Hi all,  I am in the market for an R200 longnose diff out of a Z31 300ZX, or S12 RSX, DR30 skyline, or similar, in a 3.9 ratio.  Preferably a late model one with the M12 crownwheel bolts.  The only easy to find advert for one of these was my ad back in 2007 when I sold it on this forum.  I sold the diff as I had sold the car it goes to, but as it turns out, after 18 years I got the car back late last year, so now I'm looking for the diff !  If anyone knows where to find a longnose R200 LSD with the M12 crownwheel bolts, drop me a line at [email protected] - Bonus paid if soomeone comes up with the original diff (stranger things have happened !).  Cheers   Ben D
    • Hi everyone, I used to post here a bit from 2004-2013, when I owned various Nissans, in particular my S12 RSX gazelle, which was sold in 2007.  As luck would have it, after an 18 year hiatus, the car found its way back to me last year, and over the past 11 months I have had the pleasure of restoring it with my kids.  One thing that I am after in particular is a 3.9 ratio R200 LSD for it.  I actually sold the one out of the car here back in 2007 , and it would be incredible if I could track down who I sold it to, so I can see how they have progressed over the years (and to be honest, to see whether I can get the diff back !).  Anyways, hi all and let me know "where are the R200 Longnose diffs all at these days ?  Cheers Ben D
    • Arms will be the same as the G35 or 350Z, but as above, there was a change in the lower control arm where it connects to the ball joint.  That said, you can remove the ball joint cone from your old ball joints and fit them to the new ball joints.  To be honest, I didn't think the ball joints themselves were different. The main ball joint is a bit awkward to replace, you really need to remove the steering knuckle to press out the old one.  Some people have used tools to remove it in place, but it just seemed too hard to get to. If you are going to press out/in that ball joint, then you may as well just replace the bushings in the LCA and the compression rod.  You can buy the compression rod bushing from Nissan, but the LCA bushes, you will need to go aftermarket. Much cheaper than buying the whole arm.
    • Ha, well, it's been.... a bit of a journey. Things have taken much longer than I'd hoped. I'll probably put up a thread at some stage. Hopefully soon. The car's not done any kms since my update in June though, put it that way.
