Hey guys, this is my first post so hello. I thought I'd join up on this site and get some good GTR info as well as post up the bits I have here and there. Moving on then. So here's my little paint project. Originally when I took delivery of the car, the front bumper had some slight damage on it. I was just going to repaint it silver, but somewhere along the way, I was asked by a close friend if they could try their hand at it. I knew this only meant things would get out of hand but I said okay. The artwork is by Allison La Valley of Lost Birds Art Studio (Portland, OR, USA) The car is in Misawa, Japan, where so far about 30 hours have gone into this. The plan is to finish the whole car by the end of February, so that will leave me time to build up the engine, etc before racing starts. I know some are going to hate that I allowed this, but remember it's just a car and as a matter of fact, there are 10s of 1,000s more just like it. Updates as they come!
pictures of the work so far.
Passenger Side Skirt
Driver Sideskirt Started
mirrors
Rear
Front
The work goes on.....
its not what i'm into mate,but regardless,good on you for being original.this is where innovation and trends start.it looks good,just not for me.keep up the good work.
  • 1 month later...
New engine is in. New suspension is in (JIC FLT-TARs), new seats (Sparco R2s), some other top secret Lost Birds stuff too.
Overly dramatic teaser video I was working on.
Edited by istdercollen
btw how's driving on the streets with those seats? the head supports looks like theyd limit your peripheral vision quite a bit
It's not that bad, your head isn't buried in there like you think since they are designed specifically with a helmet in mind. but they are illegal here for road use. The cops are too polite to give you a ticket for something like that though, so the world keeps turning. It will not pass inspection, however.
  • 6 months later...
Back from the dead. It's been hellish here after the earthquake and f*kushima. Everything is slowly getting back to normal, although the radioactive cloud over everyone's head is still a concern. The car was stuck in Tokyo for over a month after the disaster here, parked in an open lot that was unguarded and uncovered. The car was packed full with suspension bits, a Nismo twin plate clutch, Sparco seats that were still not installed, etc. When I came back it was covered in yellow goo, but otherwise untouched. I had to drive through f*kushima Prefecture, and the highway runs about 30km away from the nuclear plant. I felt sick the entire time. Pulling into rest stops, the only other travelers were fire fighters and rescue crews, very surreal to be there as it was happening.
Anyway, more parts on order for the November 6th Super Autobacs Time Attack at Nango Raceway in Aomori. New clutch is going in, some new lug nuts to look fly, Takata harnesses, and in a few days, Stoptech 355mm brakes at all four corners are being ordered. Should be fun! Also, I entered into a car show and pulled 1st place out of it, with a $200 prize. The show was more to raise money for relief efforts around here, so I just threw it in the donation tray afterwards. Anyway, enough talking! Back home in the garage!
    • Here is the mess that I made. That filler there was successful in filling dents in that area. But in the middle area. I can feel dents. And I've gone ocer it multiple times with filler. And the filler is no longer there because i accidently sanded it away. I've chased my tail on this job but this is something else lol. So I'm gonna attempt filler one more time and if it doesn't work I'll just high fill primer the door and see where the issues are because guidecoat is of no use atm.
    • Ok, so I think I sort of figured out where I went wrong. So I definitely overthinked it, and I over sanded, which is probably a large part of the problem. to fix it, I ended up tapping some spots that were likely to be high, made them low, filled them in, and I tackled small sections at a time, and it feels a lot better.    I think what confused me as well is you have the bare metal, and some spots darker and some are lighter, and when I run my finger across it, it' would feel like it's a low spot, but I think it's just a transition in different texture from metal to body filler.    When your finger's sliding on the body filler, and crosses over to the bare metal, going back and forth, it feels like it's a low spot. So I kept putting filler there and sanding, but I think it was just a transition in texture, nothing to do with the low or high spot. But the panel's feels a lot better, and I'm just going to end up priming it, and then I'll block it after with guide coat.   Ended up wasting just about all of my filler on this damn door lol
    • -10 is plenty for running to an oil cooler. When you look at oil feeds, like power steering feeds, they're much smaller, and then just a larger hose size to move volume in less pressure. No need for -12. Even on the race cars, like Duncans, and endurance cars, most of them are all running -10 and everything works perfectly fine, temps are under control, and there's no restrictions.
    • Update: O2 sensor in my downpipe turned out to be faulty when I plugged in to the Haltech software. Was getting a "open circuit" warning. Tons of carbon buildup on it, probably from when I was running rich for a while before getting it corrected. Replaced with new unit and test drove again. The shuffle still happens, albeit far less now. I am not able to replicate it as reliably and it no longer happens at the same RPM levels as before. The only time I was able to hear it was in 5th going uphill and another time in 5th where there was no noticeable incline but applying more throttle first sped it up and then cleared it. Then once in 4th when I slightly lifted the throttle going over a bump but cleared right after. My understanding is that with the O2 sensor out, the ECU relies entirely on the MAP tune and isn't able to make its small adjustments based on the sensors reading. All in all, a big improvement, though not the silver bullet. Will try validating the actuators are set up correctly, and potentially setting up shop time to tune the boost controller on closed loop rather than the open loop it is set to now. Think if it's set up on closed loop to take the O2 reading, that should deal with these last bits. Will try to update again as I go.
    • More so GReddy oil relocation kits, sandwich plates, etc. all use 10AN fittings. And same, I've only used 10AN and my car sees track work (circuit, doing laps, not 10 sec squirt business).
