Need your advice guys.
My car is currently suffering from massive over steer due to KU36s on the front, and a stiff rear sway bar. My question is, do I fix the problem (put Kumho on the rear and upgrade the front swaybar), or should I just hit the skidpan as I am? I figure the wangs will be painful (and possibly dangerous!) but the skidpan could be a lot of fun, and the Supra will be very easy to flick around hats with the current set up.
If it were a track day this would matter but it's DECA and there's only maybe 3-5 people who take it really seriously or are out to win it so don't worry about some oversteer it just means you will have more fun :ermm: If I do get to come along I'll be ditching the hektik wing and putting my crap rims with super crap 215 wan li tyres on. It'll be more fun that way!
Leave it as it is. Just sus out how the car is behaving on the back track, during the 80% run, and use your right foot to control the rear end :)
ie: to stop the ass end kicking out, if you do not want it to
Agreed
Man up and drive the damn thing.
Agreed
  • Replies 259
Pretty sure his car is a daily driver in which case the excessive oversteer might land him in a tricky situation one day...not everyone is a pro driver! You can counter it with some stiffness up front to induce some understeer, but keep in mind that this may only reduce the threshold for oversteer and not necessarily the effects of it once it occurs. The end result can still be some unpredictable snap oversteer which can be a nightmare if you're not on a skidpan. If you're not confident with it I'd be ditching the swaybar for something with slightly more flex.
If you have adjustable suspension, sometimes softening up the rear shocks and stiffening the front can help you out. Other than that, yeah, stick some grippy ass tyres on the rear.
Too late!
I've getting 275/35/18 KU36s on the rear this Monday. I have my first real track day the weekend after DECA at Sandown with Driver Dynamics so I want it all safe and sorted for then. The oversteer really is shocking though, I'm not talking slight, I'm talking massive! I even have to take roundabouts carefully.
Need to upgrade the brake pads, fluid and replace the front swaybar before Sandown too. Bloody money pit.
Too late!
Hey I'm going to Sandown that weekend too, so will prob see you there, hopefully you are looking at me through your front window and not your rear window :). I fitted QFM A1RM on the front and their HPX on the rear, plus the TRW 600F fluid so it should hopefully do OK.
Bloody Sandown I wouldn't have had to do all that work unless I was signed up for that, but I'm sure it'll be fun :(
I use the same fluid and the A1RM's all round.
If I can say anything for them it's get them up to temp before you go too deep under brakes. Once they are hot they rock but they aren't much chop cold.
They're also doing a number on my rotors but such is life :(
Edited by ActionDan
They're also doing a number on my rotors but such is life :)
chewed thru my new rotors in 30,000km. Lot of other people are having same problems with the A1RM's
To be honest after Sandown I may even go back to OEM pads for daily driving, and only fit the A1RM for track or the twisties. 15mins inconvenience to change the pads over as needed is worth it to not have wooden brakes during the working week which is when 90% of my driving is anyway.
Just turn up on the day, surely one person won't make it on the day for one reason or another. The fact you're there gets you straight in.
Otherwise you can sit in my car and give me advice!
Don't really wanna tow the car 2hrs down the highway for a maybe =\
See how the entry list is looking closer to the event.
wait til the last week and thats where you'll start moving up the list....
Well, I was running some figures last night and I might not be able to afford it anyway.
I'm in the house building phase where they deliver little but take quite a lot lol
At this stage I'm thinking Winton Sprints in early MAy might be more like it =\
    • Cheers. Skyline is back on the menu, can’t get rid of it. It’s like a child you don’t want, or herpes
    • I got back to Japan in January and was keen to get back on track as quickly as possible. Europe is god-awful for track accessibility (by comparison), so I picked up a first-gen GT86 in December just to have something I could jump into right away. The Skyline came over in a container this time and landed in early January. It was a bit battered after Europe, though—I refused to do anything beyond essential upkeep while it was over there. The clutch master cylinder gave out, and so did the power steering. I didn’t even bother changing the oil; it was the same stuff that went in just before I left Japan the first time. Naughty. Power steering parts would’ve cost double with shipping and taxes, so knowing I’d be heading back to Japan, I just postponed it and powered through the arm workout. It took a solid three months to get the car back on the road. Registration was a nightmare this time around. There were a bunch of BS fees to navigate, and sourcing parts was a headache. I needed stock seats for shaken, mistakenly blew 34k JPY on some ENR34 seats—which, of course, didn’t fit—then ended up having the car’s technical sheet amended to register it as a two-seater with the Brides. Then there’s the GT86. Amazing car. Does everything I want it to do. Parts are cheap, easy to find, and I don’t care what anyone says—it’s super rewarding to drive. I’ve done a few basic mods: diff ratio, coilovers, discs, pads, seat, etc. It already had a new exhaust manifold and the 180kph limiter removed, so I assume it’s running some kind of map. I’ve just been thrashing it at the track non-stop—mostly Fuji Speedway now, since I need something with higher speed after all that autobahn time. The wheels on the R34 always pissed me off—too big, and it was a nightmare getting tires to fit properly under the arches. So I threw in the towel and bought something that fits better. Looks way cleaner too (at least to me)—less hotboy, less attention-seeking. Still an R34, though. Now for future plans. There are a few things still outstanding with the car. First up, the rear subframe needs an overhaul—that’s priority one. Next, I need to figure out an engine rebuild plan. No timeline yet, but I want to keep it economical—not cutting corners, just not throwing tens of thousands at a mechanic I can barely communicate with. And finally, paint. Plus a bit of tidying up here and there.
