2010 Sau Vic Renewal Bbq / Dyno Day - Sat 27 Feb @ Re Customs
When: Sat 27 Feb
Where: RE Customs, 16 Yiannis Court, Springvale
Time: 10am start till mid afternoon (when we run out of cars)
Dyno Info:
4WD Dyno
3 power runs
$40 current SAU Vic Members
$50 for non-members
Dyno runs will be on a first come first serve basis on the day.
Prizes:
There will be prizes for:
Most power RWD
Most power AWD
Closest Guess in a Guess the KW's competition
(must be a member to receive prizes)
Membership Info:
New Membership $50 (discount of $20)
Renewals - $50 for 1 year, $120 for 3 years
Discounts are ONLY valid for the day. So come along and sign up or renew to get the discount.
Lunch:
We will provide snags and drinks for all current SAU Vic members. Non members will be required to make a gold coin donation per item.
Please post up if your attending so we have an idea of how much food to buy.
  • Replies 160
Also - if you have recently renewed...
You can renew @ the discounted rate and have your membership extended ontop of your initial renewal :D
So open to everyone that wants to take advantage of it!
I'll be there to burn the snags once more mwahahahaha
I'll try and be there.
Maybe a dumb question, but an AWD dyno can do RWD as well, right?
Yeah, it does both. The front rollers slide hydraulically into position for the front wheels of FWD or AWD cars
umm yeah Trent how much does the truck weigh? have you put it on your own dyno? :)
the stud pattern and hub centres are just too large and i cant justify shelling out for the adapters for it, the back it light (for a big truck) but i will find out. I thought about hiring the MTQ truck dyno :P
im guessing 140rwkw and 100000000nm
First come first serve hey?.......
Maybe I'll come at like 9am to book my spot lol, as I have work at 11am, so I wanna be the first! :)
If that's possible, then I'm there :P
    • Cheers. Skyline is back on the menu, can’t get rid of it. It’s like a child you don’t want, or herpes
    • I got back to Japan in January and was keen to get back on track as quickly as possible. Europe is god-awful for track accessibility (by comparison), so I picked up a first-gen GT86 in December just to have something I could jump into right away. The Skyline came over in a container this time and landed in early January. It was a bit battered after Europe, though—I refused to do anything beyond essential upkeep while it was over there. The clutch master cylinder gave out, and so did the power steering. I didn’t even bother changing the oil; it was the same stuff that went in just before I left Japan the first time. Naughty. Power steering parts would’ve cost double with shipping and taxes, so knowing I’d be heading back to Japan, I just postponed it and powered through the arm workout. It took a solid three months to get the car back on the road. Registration was a nightmare this time around. There were a bunch of BS fees to navigate, and sourcing parts was a headache. I needed stock seats for shaken, mistakenly blew 34k JPY on some ENR34 seats—which, of course, didn’t fit—then ended up having the car’s technical sheet amended to register it as a two-seater with the Brides. Then there’s the GT86. Amazing car. Does everything I want it to do. Parts are cheap, easy to find, and I don’t care what anyone says—it’s super rewarding to drive. I’ve done a few basic mods: diff ratio, coilovers, discs, pads, seat, etc. It already had a new exhaust manifold and the 180kph limiter removed, so I assume it’s running some kind of map. I’ve just been thrashing it at the track non-stop—mostly Fuji Speedway now, since I need something with higher speed after all that autobahn time. The wheels on the R34 always pissed me off—too big, and it was a nightmare getting tires to fit properly under the arches. So I threw in the towel and bought something that fits better. Looks way cleaner too (at least to me)—less hotboy, less attention-seeking. Still an R34, though. Now for future plans. There are a few things still outstanding with the car. First up, the rear subframe needs an overhaul—that’s priority one. Next, I need to figure out an engine rebuild plan. No timeline yet, but I want to keep it economical—not cutting corners, just not throwing tens of thousands at a mechanic I can barely communicate with. And finally, paint. Plus a bit of tidying up here and there.
