2010 Sau Vic Renewal Bbq / Dyno Day - Sat 27 Feb @ Re Customs
When: Sat 27 Feb
Where: RE Customs, 16 Yiannis Court, Springvale
Time: 10am start till mid afternoon (when we run out of cars)
Dyno Info:
4WD Dyno
3 power runs
$40 current SAU Vic Members
$50 for non-members
Dyno runs will be on a first come first serve basis on the day.
Prizes:
There will be prizes for:
Most power RWD
Most power AWD
Closest Guess in a Guess the KW's competition
(must be a member to receive prizes)
Membership Info:
New Membership $50 (discount of $20)
Renewals - $50 for 1 year, $120 for 3 years
Discounts are ONLY valid for the day. So come along and sign up or renew to get the discount.
Lunch:
We will provide snags and drinks for all current SAU Vic members. Non members will be required to make a gold coin donation per item.
Please post up if your attending so we have an idea of how much food to buy.
  • Replies 160
Also - if you have recently renewed...
You can renew @ the discounted rate and have your membership extended ontop of your initial renewal :D
So open to everyone that wants to take advantage of it!
I'll be there to burn the snags once more mwahahahaha
I'll try and be there.
Maybe a dumb question, but an AWD dyno can do RWD as well, right?
Yeah, it does both. The front rollers slide hydraulically into position for the front wheels of FWD or AWD cars
umm yeah Trent how much does the truck weigh? have you put it on your own dyno? :)
the stud pattern and hub centres are just too large and i cant justify shelling out for the adapters for it, the back it light (for a big truck) but i will find out. I thought about hiring the MTQ truck dyno :P
im guessing 140rwkw and 100000000nm
First come first serve hey?.......
Maybe I'll come at like 9am to book my spot lol, as I have work at 11am, so I wanna be the first! :)
If that's possible, then I'm there :P
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
