rang nizzpro back up yesterday and told them that the 1jz was what i wanted done. my reasons being that i started this hole project with wanting a 1jz and if i had decided to go a rb25, i wouldv just sold the shell and bought a r33 (which i wasn't really interested in, because i much like the 32 better). so by powerplay in may it should be on the track burning some rubber :( cheers for the input
1jz no shit :)
Edited by crazy.mofo
  • Replies 78
Of course a 1JZ will pull harder then an R33 GTST... the GTST is down on a good 20kw of power...
NEO vs VVTi 1JZ... well my R34 raced a JZX100 chaser and I won by about two car lengths. Zorsts as the only mod.
A neo RB25 will go in alot easier... it would have been my pick.
Well done mate you wont be disapointed. I see your in brissy I'd love to catch up with you when youve got it finished! im very interested too see how a 1J goes in such a light body.
Cheers
if your going to go to the effort of putting a 1j in then why not just go the 2j instead and use a r154 box? the 2j is worth stuff all more in the grand scheme of things and the 1j is not exactly a standout engine worth spending $7500 to get done. Buy a toyota supra mk3 or mz20 soarer and do the 1j it will cost bugger all as everything is bolt in.
2JZ half cuts / long engines command much more money than 1JZ.
I prefer the feel of the RB25 personally...it's a much more responsive engine; feels more fun to drive than the 1JZ and much easier to work on.
But if you're chasing big power and something different, the 1JZ is where it's at. Very torquey engines that just seem to pull and pull at any speed in any gear as long as you are on boost. They are very strong in the bottom end and never feel like you're killing them when you take them to redline. But off boost they are quite laggy due to the twin turbo setup. They have heavy ass flywheels and they sound like vacuum cleaners. Also the R154 is tough as nails but it becomes a pain in the ass to shift in a daily driver...it's a truck box with a short gearstick on it.
no no don't do what he says do what i say
no seeriously
good choice on the 1J. IMO
this is literally a pissing contest however - guys are like that. their opinion is the better option
what i WILL say however - if going the 1J - which i see you are - get a VVTI and single
much torquey-er motor. better balanced, more refined. better on fuel (i know it's a race car shut your face) it's just a better engine - YEAH it costs mroe but not MUCH more in the big scheme of things.
EDIT - another thing - 1J twin turbo is at LEAST now 14-15 years old... if you're transplanting an engine do you really want to invest money in something THAT OLD???
personally i'd have just bought an S2000
but
that's just me. and i'm better than any of you.
Edited by Mr Eps
Cheers
yer mate il shoot u a pm when its up and running. meet up some time and we can take it 4 a spin :P
not going to be a daily driver so im not worried. imma going single turbo, just my personal preference :)
yeah but he's not gay either y'know
lol
i don't get the haricut reference and as for the gay thing you guys need moar jokes
and - you're buying it for track purposes yes?
S2K is costlier than $7500 granted
but thats $7500 for ENGINE CONVERSION, not "the car" as a whole
being a track only car - you can import a De-Reg japanese one - no compliance - no rego.
so in reality an S2k really isn't "that" unattainable at all...
yes it will mainly be used on track, but is also gonna be registerd so i can drive it to the track, or spirited drives over the hills :(. i picked the shell up for about 1.5g, and im getting everything else i need for about 10g. way i look at it, 11g for a kinda different car is well worth it :D
You can make big power with a 25 too you know :laugh:
    • But first....while I was there, I also swapped across the centre console box for the other style where the AV inputs don't intrude into the (very limited !) space.  Part# was 96926-4GA0A, 284H3-4GA0B, 284H3-4GA0A. (I've already swapped the top 12v socket for a USB bulkhead in this pic, it fit the hole without modification:) Comparison of the 2: Basically to do the console you need to remove the DS and PS side console trim (they slide up and back, held in by clips only) Then remove the back half of the console top trim with the cupholders, pops up, all clips again but be careful at the front as it is pretty flimsy. Then slide the shifter boot down, remove the spring clip, loose it forever somewhere in the car the pull the shift knob off. Remove the tiny plastic piece on DS near "P" and use something thin and long (most screwdrivers won't fit) to push down the interlock and put the shifter down in D for space. There is one screw at the front, then the shifter surround and ashtray lift up. There are 3 or 4 plugs underneath and it is off. Next is the rear cover of the centre console; you need to open the console lid, pop off the trim covering the lid hinge and undo the 2rd screw from the driver's side (the rest all need to come out later so you can do them all now and remove the lid) Then the rear cover unclips (6 clips), start at the top with a trim tool pulling backwards. Once it is off there are 2 screws facing rearwards to remove (need a short phillips for these) and you are done with the rear of the console. There are 4 plugs at the A/V box to unclip Then there are 2 screws at the front of the console, and 2 clips (pull up and back) and the console will come out.
