Hey all, I'm new to Melb just moved from the ACT. In the midst of buying a skyline, probably r33 gts-t, love those :D
Anyone know where's a good place to do an inspection and compression test and what not?
Also, any good mechanics/workshops near the CBD area. I'm located in Carlton atm.
Cheers guys.
https://www.sau.com.au/forums/topic/307396-new-to-melb/
Honestly don't touch a car without an RWC! either you or him will have to fix it, so it may as well be him. Don't bother getting a dodgey roady because you will have to fix it sooner or later and you will avoid the potential defect!
https://www.sau.com.au/forums/topic/307396-new-to-melb/#findComment-5079369
lol yeah their pretty strict ey..
so just to clear things out, are FMIC allowed? How about shielded pods and BOVs and exhaust systems.. What are the "official" rules on that so that I can get the RWC for registration.
Thanks guys.
https://www.sau.com.au/forums/topic/307396-new-to-melb/#findComment-5080159
Thanks guys.
fmic arnt illegal, pods arnt either...but if you have the 2 together it makes it illegal. so one or the other. bov are illegal...exhaust systems are ok if they are 90db or under which most likely it wont be so its pretty much a no.
https://www.sau.com.au/forums/topic/307396-new-to-melb/#findComment-5080185
Well after viewing more than 10 cars, finally decided on 1. Got stateroads to send a guy to do the inspection, I must say it was really good and professional. If all things go well, should be behind the wheel of an r33 soon.
Thanks guys :down:
https://www.sau.com.au/forums/topic/307396-new-to-melb/#findComment-5088725
don't trust any RWC you get, get the car inspected. a lot of places will turn a blind eye for a little extra cash.
plus, the car doesn't need an inspection if transferring rego, so the rwc is mostly for your benefit. depending on how modified the car is you want to buy.
https://www.sau.com.au/forums/topic/307396-new-to-melb/#findComment-5099487
+1
My car had the WORST suspension of all time and it got a RWC. Worst thing is I knew the workshop that it got the RWC done at (only noticed this after I'd already purchased the car with RWC), and they are dodgy bastards who use recycled oil and shit.
https://www.sau.com.au/forums/topic/307396-new-to-melb/#findComment-5099568
    • I've searched fairly extensively among Japanese websites but found nothing really like those skirts in your photo. The closest I got was Origin Labo side skirts however they look more 'complete' in that they have a finishing piece or tab at the rear of the skirt so it blends into the bodywork, unlike the one in your pic. For that reason I'd say the skirts in your pic could be adapted from another car and they didn't include that tab piece, or those skirts aren't copied from an existing skirt but an original design. Sorry I can't help out in regard to ID'ing/sourcing them
    • Wonder if JB Weld sponsored the event lol
    • There's a big difference between a car built with millions of dollars in R&D, and someone like yourself taking a normal sporty road car, and making it 5 times more powerful. At the same time, get a modern sports car, and you can turn them up towards the 1000hp mark a lot easier too. Also, give that Lambo another 20 odd runs, and chances are it too may break something.
    • There isn’t really a cheap upgrade here. If someone made a decent, bolt in 6 speed that holds some grunt, it would do very well. The 5 speeds suck. You can put a - OSG 5 speed gear set into it. Ratios are tall so it zaps the “zing” out of it. Had one, busted it. - PPG 5 speed gear set synchro or dog’s. Ratios are even taller. - An overpriced Getrag. Nice to drive, expensive to source now. - A sequential of some sort. Expensive, very expensive. How many times do you pop a 5 speed before you throw the toys out of the cot?
    • Yes, fair call. I don't have any special love for super/hyper cars but it was impressive to watch the Lambo line up against successive skylines without any problem at all.
