Hi All,
Just came across this turbo, it is a GT3076R turbo but made to bolt up directly to the skyline manifold and dump pipe. Only modification is to the water lines.
They also do it for GT28RS, GT2871 or GT3071.
Bottom of Page 2:
http://horsepowerinabox.com/HPIAB2/category12_2.htm
Seems very interesting although I spoke to Michael from GCG and his response was:
"We used to do these bolt-on turbochargers, however, we ran into heavy boost spike issues, as the factory 6 bolt Nissan housing is just too restrictive and small on the back of a GT3076R. This was the case, whether it be machining the original housing, or using atermarket cast housings"
Just wondering if anyone has used one or if anyone has any more information around them?
  • Replies 101
Yeah thats my preferred option too, its just its $2k compared to $3k for the real one (complete kit) plus you need a new dump pipe etc.
Edited by Harey
Garrett dual ball bearing GT3076 internal wastegate:
Garrett cartridge CHRA 700177-5015
Highly ported Nissan 45V4 front housing
AVO .73 rear housing 6-bolt skyline style
bolt on, $2300 with lines from Adelaide Turbo Services
garrett chra pricing: http://www.turbobygarrett.com/turbobygarre...am_May_2007.pdf
avo rear housing : http://www.avoturboworld.com/pdf/gts_exhaust_housing.pdf
no boost spike
was using a hks 14pound actuator but upgraded just now to a garrett 18psi turbo actuator
boosts quicker and holds nicely at 1.25bar, no spike
feels very powerful, will redyno test soon
A 0.73 rear is too small IMO. OK for making sub 250, but you will have issues over this.
Anyway, much better off with an external gate if you want to make good clean power. An internal will do it, but you have to fight against it all the way, it is never easy. Just read all the threads on internal gate problems aka boost probs.
Bite the bullet and get a real Garrett 3076 WG, around $2K plus water/oil and dump pipes.
I also just found this earlier this morning.
I've been reading this http://www.skylinesaustralia.com/forums/Ch....html&st=20
and I'm put off the idea a bit by Mafia, but I'd like to see what somebody thinks of these new sizes.
Is it just a better idea to buy the 3076 they have here http://www.horsepowerinabox.com/HPIAB2/prod641.htm and then get the extra parts from somewhere else?
The more I read on this the more questions I seem to be asking...
that turbo wont physically bolt up to a skyline manifold. needs to be T3 not T25.
agree 100% on internal vs external, re: good clean power
external seems to be the way to go if you want good clean power and no issues
check out roy's rb20 td06 setup, with his proper external setup (manifold, gate, dump) his setup is bulletproof and makes tons of power, even on the rb20
Oh ok, there's a T3 they've got there too, thanks for that.
But in general, is it going to be better to just buy something like this http://www.horsepowerinabox.com/HPIAB2/prod18.htm and then find the parts other people are recommending?
Appologies if these are particularly stupid questions, I'm very new to selecting indivual parts for turbos.
Cheers,
Tim
0.73 rear doesnt sound that small. Guys are making good power with the 0.63 housing. Yes the optimal is a 0.82 housing, but 0.73 isnt far off that!
Standard R34 OP6 housing is what 0.5 something. Guys are making 250rwkw with a smaller trim hiflow wheel.
Edited by Harey
I pissed my AVO 73 housing off as it didnt like making power and i had all sorts of problems with it
put on a 82 external and it already feels better
Edited by Haines
gt3076r turbo itself is around $1800 mark? then around $500 - 600 to fit with new dump oil/water lines intake pipe and cooler pipe
pretty basic , 3k is way 2 much for a complete bolt on kit.
    • Well GTSBoy, prepare yourself further. I did a track day with 1/2 a day prep on Friday, inpromptu. The good news is that I got home, and didn't drive the car into a wall. Everything seemed mostly okay. The car was even a little faster than it was last time. I also got to get some good datalog data too. I also noticed a tiny bit of knock which was (luckily?) recorded. All I know is the knock sensors got recalibrated.... and are notorious for false knock. So I don't know if they are too sensitive, not sensitive enough... or some other third option. But I reduced timing anyway. It wasn't every pull through the session either. Think along the lines of -1 degree of timing for say, three instances while at the top of 4th in a 20 minute all-hot-lap session. Unfortunately at the end of session 2... I noticed a little oil. I borrowed some jack stands and a jack and took a look under there, but as is often the case, messing around with it kinda half cleaned it up, it was not conclusive where it was coming from. I decided to give it another go and see how it was. The amount of oil was maybe one/two small drops. I did another 20 minute session and car went well, and I was just starting to get into it and not be terrified of driving on track. I pulled over and checked in the pits and saw this: This is where I called it, packed up and went home as I live ~20 min from the track with a VERY VERY CLOSE EYE on Oil Pressure on the way home. The volume wasn't much but you never know. I checked it today when I had my own space/tools/time to find out what was going on, wanted to clean it up, run the car and see if any of the fittings from around the oil filter were causing it. I have like.. 5 fittings there, so I suspected one was (hopefully?) the culprit. It became immediately apparent as soon as I looked around more closely. 795d266d-a034-4b8c-89c9-d83860f5d00a.mp4       This is the R34 GTT oil sender connected via an adapter to an oil cooler block I have installed which runs AN lines to my cooler (and back). There's also an oil temp sensor on top.  Just after that video, I attempted to unthread the sensor to see if it's loose/worn and it disintegrated in my hand. So yes. I am glad I noticed that oil because it would appear that complete and utter catastrophic engine failure was about 1 second of engine runtime away. I did try to drill the fitting out, and only succeeded in drilling the middle hole much larger and now there's a... smooth hole in there with what looks like a damn sleeve still incredibly tight in there. Not really sure how to proceed from here. My options: 1) Find someone who can remove the stuck fitting, and use a steel adapter so it won't fatigue? (Female BSPT for the R34 sender to 1/8NPT male - HARD to find). IF it isn't possible to remove - Buy a new block ($320) and have someone tap a new 1/8NPT in the top of it ($????) and hope the steel adapter works better. 2) Buy a new block and give up on the OEM pressure sender for the dash entirely, and use the supplied 1/8 NPT for the oil temp sender. Having the oil pressure read 0 in the dash with the warning lamp will give me a lot of anxiety driving around. I do have the actual GM sensor/sender working, but it needs OBD2 as a gauge. If I'm datalogging I don't actually have a readout of what the gauge is currently displaying. 3) Other? Find a new location for the OEM sender? Though I don't know of anywhere that will work. I also don't know if a steel adapter is actually functionally smart here. It's clearly leveraged itself through vibration of the motor and snapped in half. This doesn't seem like a setup a smart person would replicate given the weight of the OEM sender. Still pretty happy being lucky for once and seeing this at the absolute last moment before bye bye motor in a big way, even if an adapter is apparently 6 weeks+ delivery and I have no way to free the current stuck/potentially destroyed threads in the current oil block.
