might as well just get a Autowatch alarm with the electric window wind up unit and then it can be wired with your turbo timer, otherwise if i had known you wanted a hardcore alarm you can also get the autowatch with a turbo timer, but it can be wired in very easily and then you can save on the installation
www.importscene.com.au ... goto the contact section, and ring Shaun Kempson. He installs Autowatch, and can order it in etc, he does a very good job (i have worked with him before), he is very proffessional and does things for a good price. He knows his way around turbo timers etc aswell. can hook anything you want up to anything and yah. He knows what he is DOING!!!
hey guyz, thanks for the input
i was kind of looking at getting a system called "viper" im not sure if it is rls in australia but in america it is wat all the viper and corvette use, got a pager and all looks very high-tec and comes recommed from my mates in the states
ok after looking around on the net, i have come 2 the consulion that i would like to get an
Clifford G5 - Avantguard 5
http://www.clifford.com/g5/default.asp
very high-tec, i really want a GPS alarm system but i dont think any one in australia does that only happens in USA. so does anyone know of a place where i could get thi system in perth nad installed?
gps would be nice mike,
but your insurance dont get any cheaper with a wizz bang alarm. The insurance is there to protect you when the car is stolen etc. and god knows you are paying for it. so you might as well put in a decent autowatch or a laserline and then make sure your insurance is paid.
dude, i think u can hook up autowatch to a GPS.
Shaun at import scene hasnt got his wired up so much like that, BUT he has it so if someone doesnt start his car a certain way ... the alarm will go off (thats if they even get that far into the car! ) But when and if something like that does happen, the car actually calls his mobile fone first and he can talk to the people in the car, and they can talk back (via microphones in the car). He can even call his car, and arm the alarm system from his mobile. (or any other phone for that matter). But yeah... if u want it... he can do it dude. Just say what u want and he can get it in and get it sorted. Some of that stuff is pretty costly though.
We have a guy on call who installs alarms .
used to work for Actions and does( did ) all the installs on the Subaru WRX keypad alarms in WA.
He will be in this arvo so give us a call.
Cheers
Ken
I have ordered a GSM alarm, just stick a pre-paid mobile sim card in it, and it will sms me when anything happens, and i can send an sms to immobilise, set alarm off, etc. also it can be tracked via gsm mobile tracking, just like a regular mobile.
That, coupled with a keypad pin immob and my regular system, should be fairly secure :)
That, coupled with a keypad pin immob and my regular system, should be fairly secure :(
where can i get this memphis ?????
    • Yeah, it's getting like that, my daughter is coming over on Thursday to help me remove the bonnet so I can install the Carbuilders underbonnet stuff,  I might get her to give me a hand and remove the hardtop, maybe, because on really hot days the detachable hardtop helps the aircon keep the interior cool, the heat just punches straight through to rag top I also don't have enough hair for the "wind in the hair" experience, so there is that....LOL
    • Could be falling edge/rising edge is set wrong. Are you getting sync errors?
    • On BMWs what I do because I'm more confident that I can't instantly crush the pinch welds and do thousands of USD in chassis damage is use a set of rubber jacking pads designed to protect the chassis/plastic adapter and raise a corner of the car, place the aforementioned 2x12 inch wooden planks under a tire, drop the car, then this normally gives me enough clearance to get to the front central jack point. If you don't need it to be a ramp it only needs to be 1-1.5 feet long. On my R33 I do not trust the pinch welds to tolerate any of this so I drive up on the ramps. Before then when I had to get a new floor jack that no longer cleared the front lip I removed it to get enough clearance to put the jack under it. Once you're on the ramps once you simply never let the car down to the ground. It lives on the ramps or on jack stands.
