hey guys
will be recieving my gt3076r .6 front .82 exh next week
what im wondering is should i go and highmount it with just a cheap ebay manifold or keep it low mounted?
am i going to gain anything besides look/exh note.
who has had exp with these and what should i look out for?
or should i just keep stock manifold and throw my ext gate off the .82 turbine?
i wanna hit 300kw with this turbo
https://www.sau.com.au/forums/topic/308634-gt3076r-manifold/
  • Replies 97
Posted Images
wont the stock manifold fall over top end around the 300kw mark?
with that 3582 it felt ok top end but thats alot bigger turbo? i really dont know, id love a etm manifold.. maybe thats what i should save for?
also im going to have to cut into exh housing to run ext gate.
Edited by l0WRB
hey guys
No offense intended but it just seems strange that you would just get rid of your old setup which had a fair bit of cash behind it and then purchase an expensive replacement turbo but not want to spend some cash on a good manifold.
What do you want from this setup really. Obviously you dont want to just hit 300rwkw peak power cause you had that with your old setup. You can hit 300rwkw with a GT3076 on a stock manifold but surely you would want the best possible setup. Especially with a 0.82 rear.
Correction Harey, he wants 300rwkw like his old setup yet without the lag.
Hav u considered having a manifold made yet Justin? if you were in sydney I could recommend someone who would probably charge less than the average expensive manifold with quality IMO far superior. If you can find someone up there in banana town who you think is that good I say get that done.. as fancy as you want it and gate where u want it also..
The 3582 spec high flow just turned out to be mega laggy with the KKR housing for some reasons. I managed better response with more power using a generic .82 turbine housing with the same CHRA. So I traded it off with a GT3076 56T .82 with cash adjustments. This will make 300rwkws with far better response.
Manifold wise if you are on external gate stock manifold is ok for 300rwkws. With Ebay manifold you have to machine both flanges flat before installation and make sure there aren't any hanging welds stuck on the inside of the manifold. Apart from that they ok to use. Also check your external gate make sure its sealing probably.
well after talking to a few ppl about these manifolds and the drama's they cause, im going to keep the factory rb25 manifold for now, until later in the year when i can afford a ETM manifold which would be perfect :D
ill just run the 50mm gate off the .82 turbine, hopefully that will hold 21psi perfect for the dyno and achieve me 300kw
harey i might have cracked the 300kw at wheels but my power delivery was horrible, not to mention the boost drop between gears and the lagg. like stao said it could have been the kkr housing, but i was so over trying dif combo's i wanted to bolt on a proven turbo and be done with it.
id love 300kw full noise and torquey mid range at 4000-4300rpm
its booked in on 5th march 2 be finished tuned and complete
didnt you have a high mount manifold for the GT35?
There is not that much lag with a 3076. I had a std hiflow before that and it was stronger down low, too quick for wet or greasy days. like driving around on ice.
The 3076 is much more progrossive at the lower street leagl speeds - but it goes hard above say 3,500-4000 rpm and gives you the power where you want it for overtaking or such.
I love mine, it made my car so much nicer to drive round town, but gets wicked when you stick it to it.
All the positive comments about the 3076 matched to RB25 are right. It will give you progressive response, 400rwhp, and top end breathing so it produces power to 7500ish on stock cams.
Rather than play with the housing, you should consider fabricating a pipe into either the manifold or the spacer plate. Frome memory Simon R-32 has some knowledge of that method.
yes i really dont want to hack up .82 turbine to fit the gate, i mite look at some other options... i would use the spacer adapter+wg flange, but mines 50mm vband, thats suited for 2bolt flange like a tial gate? hmmmm
those bolt on spacers with adaptor are too long anyway, you will need to get an exhaust shop to make one that angles the turbo which you can then get them to add on your 50mm attachment :)
altho i cant take credit for the info, i wont say who told me for his sake :ermm:
I dont know how im going to go about it now. my tuner really wants to put wastegate off turbine housing, but id prefer some other way. but im limited with stock manifold. have ppl had good success with running external gate straight off the manifold collector on top?
    • Back again. I returned to Japan in Jul/Aug to spend time with the car on my birthday and remind myself what all the sacrifice and compromise is for. It happened to line up with the monthly morning meet in Okutama, which I have been wanting to go to for a long time. It's a unique event at a unique spot with really rare, interesting, and quirky cars. It's where all the oldheads and OGs gather. The nighttime scene at DKF certainly has its place and should be experienced if you're into cars, but there's too much bad attention and negativity around it now. IMO the better time is Sunday morning at DKF or Okutama; it's more chill and relaxed. I'm glad I was finally able to go, but not sure it's worth the drive from all the way from Nagoya immediately the day before, unless I was already staying in Tokyo for the days right before the meet, because you have to wake up quite early to make it in time. Funnily enough though I didn't drive the car all that much this trip because it was just too damn hot. While there were zero issues and running temps were nominal and the A/C was strong, RBs already run crazy hot as it is. Sure, it took it all like a champ but something about driving these cars in the ridiculous heat/humidity bothers me and makes me feel like I'm asking too much of it. I'm just me being weird and treating the car like a living thing with feelings; I'm mechanically sympathetic to a fault. Instead I was mainly driving something else around - a KX4(silver) 2001 X-Trail GT, that I acquired in May. There's a few different flavors to choose from with Xs, but visually it's the Nissan version of the Honda CR-V. Mechanically it's a whole different story as this, being the top-trim GT, has an SR20VET mated to a four-speed auto and full-time AWD! It was a very affordable buy in exceptional condition inside and out, with very low mileage...only 48k kms. Most likely it was owned by an older person who kept it garaged and well-maintained, so I'm really happy with how it all worked out. It literally needs zero attention at the moment, albeit except for some minor visual touch-ups. I wanted something quirky, interesting, and practical and for sure it handily delivers on all three of those aspects. I was immediately able to utilize the cargo and passenger capacity to its full extent. It's a lot of fun to drive and is quite punchy through 1st and 2nd. It's very unassuming -in the twisty bits it's a lot more composed than one would think at a glance- and it'll be even better once I get better tires on it(yes, it's an SUV but still a little boat-y for my liking). So...now I have two golden-era Nissans in silver. One sports car and one that does everything else; the perfect two-car solution I think👍 The rest of the trip...I was able to turn my stressed brain off and enjoy it, although I didn't quite get to do as much as I thought. I did some interesting things, met some interesting people, and happened into some interesting situations however, that's all for another post though only if people really want to know. Project-wise, I went back to Mine's again to discuss more plans and am hoping to wrap that up real soon; keep watching this space if that interests you. Additionally, while working in the tormenting sweatbox that is the warehouse, I was able to organize most of the myriad of parts that my friend is storing for me along with the cars, and the 34 has a nice little spot carved out for it: And since it can get so stupid hot in there, that made it all the more easy -after I was standing there looking at the car and said 'f**k it'- to finally remove all the damn gauges that have mostly been an eyesore all this time. Huzzah. The heat basically makes the adhesive backing on the gauge mounts more pliable to work with, so it was far less stressful getting this done. I didn't fully clean it up or chase the wiring though; that will happen once I have the car in closer possession. Another major reason to remove all that stuff is to give people less reasons to get in my car and steal s**t while it's being exported/imported when/if the time comes, which leads us to my next point... ...and that is even though it's time in Japan is technically almost up since it's a November car and the X would be coming in March, I'm still not entirely sure where my life and career is headed; I don't really know what the future looks like and where I'm going to end up. I feel there's a great deal of uncertainty with me and as a result of that, it feels like I'm at a crossroads moreso now than any point in my life thus far and there are some choices I need to make. Yes, I've had some years to consider things and prepare myself, however too much has happened in that time to maintain confidence and everything feels so up in the air; tenuous one might say. Simply put, there's just too much nonsense going on right now from multiple vectors. Admittedly, I'm struggling to stay in the game and keep my eyes on the prize. So much so in fact, that very recently I came the closest I ever have before to calling it quits outright; selling everything and moving on and not looking back. The astute among you will pick up on key subtext within this paragraph. In the meantime I've still managed to slowly acquire some final bits for the car, but it feels nice knowing there's not much left to get and I'm almost across that finish line; I have almost everything I'll ever want for my interpretation and expression on what it is I think an R34 should be. 'til later.
    • Thanks for that, hadn’t used my brain enough to think about that.
    • Also playing with fire if they start to flow more air down low than what the stock twins can. It's not even up top you need to worry, it can be at 3000rpm and part throttle and it's getting way more flow than it should.
    • Any G40/1000 or G40/1250 results out there?
    • You still want a proper tune on the stock ECU though. Stock tune + stock ECU with GT-SS/-9s is probably playing with fire if you're running more than stock airflow/power.
