Hi every one. This is my result today with a HyperGears ATR43G4 600HP turbo externally gated on a stock RB25det.
Its got a .82 turbine housing running a .70 Comp cover with anti surge slots. Turbo's not brand new I've been told it came off LOWRB's KKR high flow setup, now running a Hypergear's .82 ATR43 turbine housing with RB25's OEM bolt on dump pattern.
Modifications needed for installing:
It needed 1x 20mms spacers to space out the comp housing from manifold.
The inner water line had to be bend as turbine housing was in the way.
Turbo's got a 4inch mouth, which I relocated the Z32 AFM between cooler piping and bolted on a 4inch 45 degrees elbow pipe to a Pod filter.
My car's a 94 model R33 S1. Its got:
850cc high flowed injectors from Created
Ebay cooler kit
Tomei 260 Duration by 8.5mm lift Cams
3inch exhaust with metal cat.
Tail 38mm external gate vented to atmosphere (drilled on top of stock manifold)
Z32 AFM
Z32 ECU with nistune chip and modified loom
This car has previously tuned on HyperGear's high flowed turbo at 240rwkws.
Now. 301rwkws / 403rwhp on 18psi full boost at 4500RPM . Car’s feels very strong on road and goes crazy after 4500RPM :rofl:.
Turbo, installation, and dyno tune costed me a total of $1000. Big Thanks to Nick at Phase autos and Stao from Hypergear.
Edited by kwickr33
tomei cams might help it come on earlier? plus the better turbine housing not kkr crap lol.
what exhaust manifold are u using kwikr33?
my bad just read tial gate on top of stock manifold
Edited by l0WRB
That's always a hot debate item :)
I had my GT3040 (600hp) .82 rear, making 17/18psi by 4200rpm (280rwkw) factory cams. That was with a rather restrictive 3" exhaust... so might have been sooner & more power but i'll never know that stories end! :rofl:
So it's always subjective about cams in a lot of cases. IMO you don't need them... i certainly didn't. Nor did guilt-toy on his setup (a larger GT35).
I know he was going to test some cams i think for the sake of it, not sure what eventuated there though...
I did some comparison on the dynosheet page. It appears that RB25det with cams has better response then the people who doesn't.
Today's tune is not bad, but its still got abit of miss up the top not sure if the stock coil packs are getting old.
But yea external gate and cams would make a difference to boost and power curve.
You sure? I thought all the part numbers for the Procams were for RB20/RB25/RB26 which would mean no VCT and that the Poncams which are only listed as RB25 ones with NVCS were the only ones that supported VCT.
Nice work! Its hard to see how laggy it is as the axis is in road speed not rpm. But it sure looks to sit at 300rwkw for a long time!!!
So you mean the turbo purchase, the installation of the turbo and the tuning was $1000?? Or excluding the purchase of the turbo?
Mmm you might be right actually... :D
either way good result!
Its currently running a RB25de cam gear with out the VCT. The $1000 was including the turbo, installation, all the bits for it and dyno time. I don't think Stao would offer some thing like that unless he wants some one to guinea cop his new turbos :( . After a set of spark plugs she's running pretty smooth. I'm considering to rise 3 more psi and see what she gets. Stao will you pay for my dyno time :) ?
Nick believe KM/H is more accountable. I had a look through the dynosheet section and it seems KMH/RPM scale varies from dyno to dyno.
I'm taking a average sacle of:
1KM = 39RPM. So you can work it out:
65 : 2535
85 : 3315
105 : 4095
125 : 4875
145 : 5655
165 : 6435
175 : 6825
His dyno's analyzer is broken. it can only show Power , speed and torque at this stage. Probably can get the car to run on another dyno once its tuned.
kwickr33: Let me know when you want to run on more boost. I can cover your dyno time thats not a problem.
65 : 2535
85 : 3315
105 : 4095
125 : 4875
145 : 5655
165 : 6435
175 : 6825
id say hes too lazy to calibrate the rpm :) jks
    • Hi, is the HKS  Tower Bar still available ? negotiable ? 🤔
    • From there, it is really just test and assemble. Plug the adapter cables from the unit into the back of the screen, then the other side to the car harness. Don't forget all the other plugs too! Run the cables behind the unit and screw it back into place (4 screws) and you should now have 3 cables to run from the top screen to the android unit. I ran them along the DS of the other AV units in the gap between their backets and the console, and used some corrugated tubing on the sharp edges of the bracket so the wires were safe. Plug the centre console and lower screen in temporarily and turn the car to ACC, the AV should fire up as normal. Hold the back button for 3 sec and Android should appear on the top screen. You need to set the input to Aux for audio (more on that later). I put the unit under the AC duct in the centre console, with the wifi antenna on top of the AC duct near the shifter, the bluetooth antenna on the AC duct under the centre console The GPS unit on top of the DS to AC duct; they all seem to work OK there are are out of the way. Neat cable routing is a pain. For the drive recorder I mounted it near the rear view mirror and run the cable in the headlining, across the a pillar and then down the inside of the a pillar seal to the DS lower dash. From there it goes across and to one USB input for the unit. The second USB input is attached to the ECUtec OBD dongle and the 3rd goes to the USB bulkhead connected I added in the centre console. This is how the centre console looks "tidied" up Note I didn't install the provided speaker, didn't use the 2.5mm IPod in line or the piggyback loom for the Ipod or change any DIP switches; they seem to only be required if you need to use the Ipod input rather than the AUX input. That's it, install done, I'll follow up with a separate post on how the unit works, but in summary it retains all factory functions and inputs (so I still use my phone to the car for calls), reverse still works like factory etc.
    • Place the new daughterboard in the case and mount it using the 3 small black rivets provided, and reconnect the 3 factory ribbon cables to the new board Then, use the 3 piggyback cables from the daughterboard into the factory board on top (there are stand offs in the case to keep them apart. and remember to reconnect the antenna and rear cover fan wires. 1 screw to hold the motherboard in place. Before closing the case, make a hole in the sticker covering a hole in the case and run the cable for the android unit into the plug there. The video forgot this step, so did I, so will you probably. Then redo the 4 screws on back, 2 each top and bottom, 3 each side and put the 2 brackets back on.....all ready to go and not that tricky really.
    • Onto the android unit. You need to remove the top screen because there is a daughterboard to put inside the case. Each side vent pops out from clips; start at the bottom and carefully remove upwards (use a trim remover tool to avoid breaking anything). Then the lower screen and controls come out, 4 screws, a couple of clips (including 3 flimsy ones at the top) and 3 plugs on the rear. Then the upper screen, 4 screws and a bunch of plugs and she is out. From there, remove the mounting brackets (2 screws each), 4 screws on the rear, 2 screws top and bottom and 3 screws holding in the small plates on each side. When you remove the back cover (tight fit), watch out for the power cable for the fan, I removed it so I could put the back aside. The mainboard is held in by 1 screw in the middle, 1 aerial at the top and 3 ribbon cables. If you've ever done any laptop stuff the ribbon cables are OK to work with, just pop up the retainer and they slide out. If you are not familiar just grab a 12 year old from an iphone factory, they will know how it works The case should now look like this:
    • Switching the console was tricky. First there were 6 screws to remove, and also the little adapter loom and its screws had to come out. Also don't forget to remove the 2 screws holding the central locking receiver. Then there are 4 clips on either side....these were very tight in this case and needed careful persuading with a long flat screw driver....some force required but not enough to break them...this was probably the fiddliest part of the whole job. In my case I needed both the wiring loom and the central locking receiver module to swap across to the new one. That was it for the console, so "assembly is the reverse of disassembly"
