  • Replies 122
Iv found a daily driven car that's also used on track running a bigger version 0.73ar as mind are 0.64 or 0.61 can't remember that's running hks 272 with 10.5mm lift with springs retainers and seats. And ported head. Although its making 720hp..
Full boost around 6000rpm sounds about right, which means you'll need to change each gear at over 8000rpm to keep on boost.
I'd stick with mild cams ~270° max, with moderate lift. High lift and duration cams are harder on the valve train. The large turbos will extend the top end significantly anyway. Just focus on getting a lighter and stronger reciprocating mass. Get some strong and light pistons, rods, nice bearings and get the crank checked. Probably look at a dry sump setup.
Can't see a stock RB26 holding onto those revs at high boost for long, especially on a track.
As per the above post, given the fact that your power band will be moved up between 6,000 and 8,000+ rpm.
I am running 272 deg cams at 10.5 mm lift and these are probably not enough to support such high rpm operation. Their efficiency range is much lower rpm, probably coming on at between 3 and 4000 rpm, which is suited to my longer-stroke, slower revving 3.1 and smaller turbos. Yes going bigger with cams means more doughy down bottom - it will be slower off boost than a VL commodore - but for that size turbo you are optimising for high RPM operation. I think the above suggestion about 280 deg would be the minimum, as you will need big duration to maintain 'acceptable' ramp angles.
And your mum probably won't be impressed if you throw her the keys to drive it down to the shops, as per your thread about the turbos, but that's a given for this setup.
Decided to ditch these and start on building a new engine.
Your engine is more than likely capable of high 300s if you choose the appropriate turbo. Shouldn't need to rebuild it, what turbo are you thinking of replacing it with?
At the moment looking into building a stroker engine. I know the obvious for streetability and response the choice for turbo are twin bolt ons and they will punch out the numbers i want but as iv said somewhere iv always wanted a single turbo 26. I thought people are getting decent results from mid sized singles these days?
My personal preference is for a single, tricky to match or better a good twin setup but definately possible.
That said is it your 2835's on ebay atm?... i think i need them, whether or not i win them is another story :P
Na they aren't yet mate. They'll be up soon tho. Do you want me to let you know when they are?
i'll keep an eye out, set my ebay snipe for the pair on there now so we will see how it goes.
With the stroker my brother who's a mechanic is gonna help do all the non critical rb26 stuff. He isn't in a performance scene but is full of knowledge when it comes to all mechanical stuff. And has put me onto an engineering shop in addl who's build some of adel hardest gtr's
    • Next on the to-do list was an oil and filter change. Nothing exciting to add here except the oil filter is in a really stupid place (facing the engine mount/subframe/steering rack). GReddy do a relocation kit which puts it towards the gearbox, I would have preferred towards the front but there's obviously a lot more stuff there. Something I'll have to look at for the next service perhaps. First time using Valvoline oil, although I can't see it being any different to most other brands Nice... The oil filter location... At least the subframe wont rust any time soon I picked up a genuine fuel filter, this is part of the fuel pump assembly inside the fuel tank. Access can be found underneath the rear seat, you'll see this triangular cover Remove the 3x plastic 10mm nuts and lift the cover up, pushing the rubber grommet through The yellow fuel line clips push out in opposite directions, remove these completely. The two moulded fuel lines can now pull upwards to disconnect, along with the wire electrical plug. There's 8x 8mm bolts that secure the black retaining ring. The fuel pump assembly is now ready to lift out. Be mindful of the fuel hose on the side, the hose clamp on mine was catching the hose preventing it from lifting up The fuel pump/filter has an upper and lower section held on by 4 pressure clips. These did take a little bit of force, it sounded like the plastic tabs were going to break but they didn't (don't worry!) The lower section helps mount the fuel pump, there's a circular rubber gasket/grommet/seal thing on the bottom where the sock is. Undo the hose clip on the short fuel hose on the side to disconnect it from the 3 way distribution pipe to be able to lift the upper half away. Don't forget to unplug the fuel pump too! There's a few rubber O rings that will need transferring to the new filter housing, I show these in the video at the bottom of this write up. Reassembly is the reverse Here's a photo of the new filter installed, you'll be able to see where the tabs are more clearing against the yellow OEM plastic Once the assembly is re-installed, I turned the engine over a few times to help build up fuel pressure. I did panic when the car stopped turning over but I could hear the fuel pump making a noise. It eventually started and has been fine since. Found my 'lucky' coin underneath the rear seat too The Youtube video can be seen here: https://www.youtube.com/watch?v=uLJ65pmQt44&t=6s
    • It was picked up on the MOT/Inspection that the offside front wheel bearing had excessive play along with the ball joint. It made sense to do both sides so I sourced a pair of spare IS200 hubs to do the swap. Unfortunately I don't have any photos of the strip down but here's a quick run down. On the back of the hub is a large circular dust cover, using a flat head screw driver and a mallet I prised it off. Underneath will reveal a 32mm hub nut (impact gun recommended). With the hub nut removed the ABS ring can be removed (I ended up using a magnetic pick up tool to help). Next up is to remove the stub axle, this was a little trickier due to limited tools. I tried a 3 leg puller but the gap between the hub and stub axle wasn't enough for the legs to get in and under. Next option was a lump hammer and someone pulling the stub axle at the same time. After a few heavy hits it released. The lower bearing race had seized itself onto the stub axle, which was fine because I was replacing them anyway. With the upper bearing race removed and the grease cleaned off they looked like this The left one looked pristine inside but gave us the most trouble. The right one had some surface rust but came apart in a single hit, figure that out?! I got a local garage to press the new wheel bearings in, reassemble was the opposite and didn't take long at all. Removing the hub itself was simple. Starting with removing the brake caliper, 2x 14mm bolts for the caliper slider and 2x 19mm? for the carrier > hub bolts. I used a cable tie to secure the caliper to the upper arm so it was out of the way, there's a 10mm bolt securing the ABS sensor on. With the brake disc removed from the hub next are the three castle nuts for the upper and lower ball joints and track rod end. Two of these had their own R clip and one split pin. A few hits with the hammer and they're released (I left the castle nuts on by a couple of turns), the track rod ends gave me the most grief and I may have nipped the boots (oops). Fitting is the reversal and is very quick and easy to do. The lower ball joints are held onto the hub by 2x 17mm bolts. The castle nut did increase in socket size to 22mm from memory (this may vary from supplier) The two front tyres weren't in great condition, so I had those replaced with some budget tyres for the time being. I'll be replacing the wheels and tyres in the future, this was to get me on the road without the worry of the police hassling me.
    • Yep, the closest base tune available was for the GTT, I went with that and made all the logical changes I could find to convert it to Naturally Aspirated. It will rev fine in Neutral to redline but it will be cutting nearly 50% fuel the whole way.  If I let it tune the fuel map to start with that much less fuel it wont run right and has a hard time applying corrections.  These 50% cuts are with a fuel map already about half of what the GTT tune had.  I was having a whole lot of bogging when applying any throttle but seem to have fixed that for no load situations with very aggressive transient throttle settings. I made the corrections to my injectors with data I found for them online, FBCJC100 flowing 306cc.  I'll have to look to see if I can find the Cam section. I have the Bosch 4.9 from Haltech. My manifold pressure when watching it live is always in -5.9 psi/inHg
    • Hi My Tokico BM50 Brake master cylinder has a leak from the hole between the two outlets (M10x1) for brake pipes, I have attached a photo. Can anyone tell me what that hole is and what has failed to allow brake fluid to escape from it, I have looked on line and asked questions on UK forums but can not find the answer, if anyone can enlighten me I would be most grateful.
    • It will be a software setting. I don't believe many on here ever used AEM. And they're now a discontinued product,that's really hard to find any easy answers on. If it were Link or Haltech, someone would be able to just send you a ECU file though.
