  • Replies 122
No probs mate. Sorry i took some of my replies over the top.
Can we get back to the original topic?
If i decide to keep these, what area of cams would best suit them?
I guess my 3 options 1. Got them here and try make the most out of these. 2. Sell off and buy what was suggested or 3. Sell off and buy a single kit..
But can we stick to the topic at the moment. About te best bump stick for this set up?
What do these compare to the -10 turbos??
They would be similar but the -10's would be more efficient & produce better hp. My advice to use these on your block get some 270 cams with a lift of min 10.25 you spend money on a port job I suspect you could improve spool by 500rpm. You will need to spin the engine to 9k to get the most from these.
Dunno if i wanna go to full on on this engine. As we are thinking of building another engine up. Which would better suit these. Would these suit other engines as single? Like sr and rb 20and 25's??
Do you suffer from ADD? you have been told 10-20 times
SELL THE 2835s! not one single person EVER has said keep them, every single person has said SELL THEM
BUY -5s and build a stroker.
Once again not a single person has said go a SINGLE especially not a T04z, EVERYONE said don't use a T04z, get twins that look stock, are your cheapest option, and build a 3L rb30, also your cheapest option if you are building a motor.
end of story, stop asking the same questions and READ what has been said MULTIPLE times. If they are laggy on an rb26s they will be even laggier on an sr20,rb20,rb25, they are all smaller capacity, you do realise that capacity is one of the major factors influencing spool on a turbo yes?
Sorry I lost my patience, but there is only so much I can read. Please do us all a favour and re read this thread 2 times, every single post, twice, all your questions have been answered.
Edited by Rolls
sell, purchase GT2860-5 and drop in tomei cams, plus some cam gear pulley wheels, for under $3500 total.
Tomei procams, in/ex 270, 10.25 lift, $825 delivered for the pair - http://www.ebay.com.au/itm/Tomei-procam-camshaft-skyline-rb26-det-r34gtr-in-ex-270-/140424051691?pt=AU_Car_Parts_Accessories&hash=item20b1ecfbeb
garret GT2860-5, pair $2500 delivered, http://www.ebay.com.au/itm/GARRETT-GT2860R-5-x2-TURBO-KIT-Nissan-skyline-rb26-det-/140420140354?pt=AU_Car_Parts_Accessories&hash=item20b1b14d42
Im using basic 'no-name' brand camgear wheels in my Rb26, with Greddy street-special camshafts to suit R34 GTR (using R34 CAS), 87mm CP pistons, ported head including HKS cam springs, built bottom end for track including HKS oil pump, sump/head baffles, oil-return, Power-fc with 550cc injectors, etc. Turbo's in my case are the downfall, using stock turbos highflowed with steel wheels. Engine built to be capable of over 350rwkw, turbo's only capable of pushing the engine to perhaps a max 300rwkw. One day will upgrade to GT2860-7's. Currently response is simply awesome, with loads of torque. Running-in tune only atm.
I seriously suggest James that you match the turbo's to the engine. Too large (as is the case I feel with your 2835's) and you wont be happy with the end result. Slightly on the smaller side and you'll be very well pleased with the repsonse of the entire package. For the street -5's would be on the large side but capable of 400rwkw, -7's would be perfect and capable of up to 350rwkw.
Some interesting info. I'm just gonna sell them off and build something else. I met and had a good talk to someone that was a proprietor of a shop in adelaide most drift cars. But had some good input for me and said he'd be happy to answer/help out with anything.
    • Yeah well per the video it took 15s for the stock unit to start up....even if I give it a few seconds discount for starting that is at least 12 sec before you get a reverse camera if you are trying to leave a park.  The android unit is way faster, but 2016 for the stock unit is a long time ago in consumer electronics
    • Yea that’s why I said ima test them with multimeter and see the reads.
    • Only at idle. Isn’t a problem when rev it seems.
    • @Haggerty This seems silly to ask, but are you confident in your ability to tune the Haltech?
    • Next on the to-do list was an oil and filter change. Nothing exciting to add here except the oil filter is in a really stupid place (facing the engine mount/subframe/steering rack). GReddy do a relocation kit which puts it towards the gearbox, I would have preferred towards the front but there's obviously a lot more stuff there. Something I'll have to look at for the next service perhaps. First time using Valvoline oil, although I can't see it being any different to most other brands Nice... The oil filter location... At least the subframe wont rust any time soon I picked up a genuine fuel filter, this is part of the fuel pump assembly inside the fuel tank. Access can be found underneath the rear seat, you'll see this triangular cover Remove the 3x plastic 10mm nuts and lift the cover up, pushing the rubber grommet through The yellow fuel line clips push out in opposite directions, remove these completely. The two moulded fuel lines can now pull upwards to disconnect, along with the wire electrical plug. There's 8x 8mm bolts that secure the black retaining ring. The fuel pump assembly is now ready to lift out. Be mindful of the fuel hose on the side, the hose clamp on mine was catching the hose preventing it from lifting up The fuel pump/filter has an upper and lower section held on by 4 pressure clips. These did take a little bit of force, it sounded like the plastic tabs were going to break but they didn't (don't worry!) The lower section helps mount the fuel pump, there's a circular rubber gasket/grommet/seal thing on the bottom where the sock is. Undo the hose clip on the short fuel hose on the side to disconnect it from the 3 way distribution pipe to be able to lift the upper half away. Don't forget to unplug the fuel pump too! There's a few rubber O rings that will need transferring to the new filter housing, I show these in the video at the bottom of this write up. Reassembly is the reverse Here's a photo of the new filter installed, you'll be able to see where the tabs are more clearing against the yellow OEM plastic Once the assembly is re-installed, I turned the engine over a few times to help build up fuel pressure. I did panic when the car stopped turning over but I could hear the fuel pump making a noise. It eventually started and has been fine since. Found my 'lucky' coin underneath the rear seat too The Youtube video can be seen here: https://www.youtube.com/watch?v=uLJ65pmQt44&t=6s
