Giveway, mate there are PLENTY of shite 30/31's around, no wonder you havent seen any real good ones!
imagine this, in the early 80's nissan was making HUGE technological investigations ino atessa, turbos, hicas, and alot of what we see today.
The DR30 was the first car to have the atessa system built, it was on prototypes only
The FJ20det was an insane engine for its time, 205hp or similar from a factory 2litre was unheard of back then
in Australia, as Cazz will show us, the DR30 was a RIPPER at the track
There are similar external size features with the R31, but inside and what not the 30's and 31's are pretty much completely different cars. the Aussie R31 really isnt a true skyline, as it was made HERE and not Factory 5 in japan.
Tag along with us th Skyline Nationals where this year ALOT of R30's will be flying their flags... Im really understanding when you say you not keen on them, perfectly understandable. Only a small handfull are actually any good.
i might be needing a detail too, so feel free to have a blap around the street when you do... ( i have driven it in anger for the last 3 years, done 40,000 km and still cant break it, and believe me Ive tried!)
  • Replies 179
Well that explains why they've always had a "bogan" feel to me, I've probably only seen the aussie made ones. Your points have been duly noted.
http://www.wendycainphotography.com/beeone...-6R16x95-19.jpg
That one I don't mind. I guess I just need to take a real one for a drive. I actually hated R33/34 skylines because of all the wogged up ricers I'd seen. Then I saw my friends with virtually no visual modifications but a lot of money and time spent under the bonet and I saw what the car could be. Ended up buying it 2 weeks later.
The one in that first photo Eiji, I would HAPPILY trade my 33 plus cash for it....f**king BEAUTIFUL car...wow.
i tried selling miranda, and still didn't have enough cash.
females dont know how to use computers yet, do they??
Incase people weren't aware the pic of all of SAU was sent into a Canberra magazine called "Torque Canberra" (if I remember correctly) and it was published. Its a free magazine but the only place that I know you can get it from is Trojan in Mitchell, I may be wrong but that is the only place i have seen it.
  • 5 weeks later...
    • Did and sync timing with light
    • Have you done the Ignition Sync Wizard in the AEM software?
    • Find out what RPM it was idling at with the IACV unplugged. It's very weird that the rpm didn't change at all, and then it stalled. When it stalls is it nearly like a switch off, like you've turned the engine off? Or is it more stutters and sputters and coughs to death over a few seconds? Or does the RPM just slowly keep going down and down? Have you done a test of trying to start it with the AFM unplugged? Does it still die?     If you Follow Josh's advice on using Nistune to check the voltages (which is a perfect method!) if you see anything out of wack voltage wise, THEN get the multimeter out and read the voltage directly at the sensor. If the two vary, then you're now looking for a wiring issue vs a sensor issue. So be aware, what the ECU sees, may not be what the sensor is actually saying too...
    • You very likely need to get it on a dyno and tune it. My assumption is, you've got an RB25DET tune in it, which has a different manifold, different injectors, and different cams as a minimum. What O2 sensor are you running?   When you say it runs extremely rich from idle all the way to redline, is this just free revving it you see that?
    • I seem to the be only person that is using a Haltech 2500 on an NA motor, I've installed a Bosch DBW throttle body to the OEM intake manifold and am having problems maintaining AFR even with the wideband o2.  It will run extremely rich at idle and up to redline, but under load it will go extremely lean in the 20s and i'm essentially having to rev it over 4k and feather the clutch to get it up to speed.  I've read a few other threads of about the butterfly, it seems removing the vacuum to it is supposed to have it remain open, i've noticed no difference under 4k with the vacuum line to it plugged.  I'm hoping someone here has had luck using the NA manifold with Haltech, and if they happen to have a tune for it.
