NSW: bling +100 offset rims slammed.
VIC; bling -100 offset rims slammed.
Either way, they both seem a rather pointless to me, this "HellaFlush" trend makes me LOL.
what style would you prefer? everyone getting around with gtr/r400 bars and mspec side skirts.. oh and lets not forget the "gtr" wing on the gts-t..and the odd badge for good measure
sickkkkkk :)
sickkkkkk :P
r33 40th anniversary?
with you on the good fitment though.. how could anyone be against that :D
sickkkkkk :P
meh, i like cars stockish, i wish my car had a gtst front bar.
function over form. functional ride height, functional tyre fitment, not spending money on kits that dont do shit for aero/on cars that dont go on the track etc.
im loving all the hellaflush business.
Next car will def have tuff fittment
sunken is bad, but hellaflush is poser spec. is there no middle ground? lipped guards with normal tyres at functional height?(good geo, clearance etc)
oops, it wont pull the bitches. honestly, when has a "hellaflush" car ever gotten you a quality girl?, or is it about cred with other guys? insecure much?
I am sure for some it could be they're personal taste, but for most it seems to just be a groupy/"trend" thing.
stock looking 32gtst with 33GTR rims= win, stock looking 33/34gtst/gtt with 34GTR rims = win.
i think we have complete opposite ideas on car modifying.
what you have described sounds like stock ugly shit..
i dont see how hellaflush is poser spec at all but whatever if you dont know what your talking about its a pointless converstaion.
who said anything about pulling bitches? is that what your skyline is for.. my car is functional its for sliding.. if i wana pull bitches ill take my lexus out.
in closing you seem like an idiot, you have a baseless argument soo u start talking about pulling bitches?
+1
but it all comes down to the primary use of the car.
If its just being driven as a daily, 200kw-300kw wont do much good in peak hour traffic. Hence they spend money on cosmetics.
The ideal height for perfect handling is 350mm guard to hub and to the majority of skyline owners this is too high. Let them enjoy their style of modification whilst you easily drive over speedhumps hehe :P
When guys in melbourne start aesthetically modding though, that's when the problem comes. They either do it well (hamish's car for example) or they go lebo spec ethnic candy colour with shitty wheels and badly fitted kits.
:D
Whats bad about them?
I heard they are very heavy wheels?
Or are they just shit overall?
the look shit
they are heavy
they look shit
build quality is shit
they look shit
offsets are shit
they look shit
they are heavy
they look shit
sickkkkkk :P
so fkn true mang!
does me just fine in traffic ;)
damn straight..... 350mm looks aids
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
