On the topic of Real Estate agents...
The muppets who manage the property I am renting, recently did an inspection, and claimed the carpet is dirty...when in actual fact it was like that when I moved in (brand new place), yet it's now MY responsibility to clean it. Got photo's and the initial inspection I filled out to prove them wrong, but the tenancy union are a bunch of weak f**ks.
if your talking about your vacating inspection it is mandatory for the tenant to steam clean the carepts upon exit it will be clearly stated in your lease, if your still in the property and not moving out you can tell them to get fkd but keep in mind when you go to leave you will have to do it VCAT wont help you with it and yes the tenants union are useless if you got questions feeel free to pm me or something i did property management in my early days :blush:
Well I'm going to move out anyway, but yeah, aware that we need to steam clean it before we leave. Just a pain in the arse that the place was dirty when I initially moved in, and the fact that I had to wait a couple of months for the correct remote for my split system in the living room. Very unprofessional on their part me thinks.
yehh i hear ya man common problem unfortunately all that you mentioned is up to the landlord and they are the biggest tightarses/lazy mofo's around i found they are harder to deal with then tenants usually but the tenants are the ones who always cop the shite :(
f**kin bummed i missed goodlife.. i thought it was on the 31st -_-
started playing MW2 online on ps3.
damn there are some pretty good people on there. like respawn and bang your dead
add(own) me peeps. sam3075
hmmmmm... ive lost 6 hours of memory.
i remember our cricket team thrashing the shite out of our opponents at the grand final... then i remember going back to the club rooms and having about 4 beers, then shotgunning a beam and cola then waking up on our couch nekkid at 8am this morning....
i also dont seem to have my phone any more... or my oakleys... lol
i do have my sim card though which has me intrigued as to the phones fate
dropped in the loo/river for sure. check under your nails to figure out which.
    • So, before putting them in I need to understand the stock ride height. This is how I measured it: First, check the diameter of the wheel's centre cap, it was 52mm. Then put a piece of masking tape approximately across the centre and measure 27mm (half) from at least 3 sides to get a reasonable idea of the centre of the wheel cap. Mark that with a horizontal line as one measuring point. Then, directly above the wheel on the guard, put another piece of masking tape in approximately the centre. Use a string line to find out the point on the guard above the centre of the wheel cap and mark that. Then it is simple, just a tape measure to check the distance from centre of the wheel to the centre of the guard. Final results where  LF: 381mm RF: 379mm LR: 401mm RR: 400mm Pretty even considering they are 120,000klm old factory springs, lets call that 380 front and 400 rear.
    • So....knowing that I have a problem with power steering temps on track and another Wakefield day booked in next Friday, I've done the obvious thing They are very reasonably priced at $1650, considering they are a big monotube shock, double height adjustable (don't have to change pre-load to change ride height), one way adjustable damping and standard sized and customisable springs if you want something other than what comes with them. They come with 9kg/mm front and 4.5kg/mm front and I went with that as a starting point because I'll add adjustable sway bars too https://justjap.com/products/bc-racing-coilover-kit-ds-ds-infiniti-q50-v37-14-current#description Unfortunately they didn't come with rear strut tops so I've re-used the factory ones which was a bit of a pain. Also, the adjuster for the rear shock will be an absolute nightmare to get at, and while there are extensions in the kit I can't see any way you can actually attach or use them
    • I also had 2 bulbs blow at once, years ago in the stagea. made for a fun drive home. The issue was the voltage regulator had failed in the alternator and it was giving 15+ volts. Really, I was lucky all that was fried were the headlight bulbs. So, I'd suggest you check the voltage across your battery terminals with the car running and warmed up. Yes, you will need a multimeter to do so, sorry.
    • Good work to think to check that, and thanks for coming back to post up the outcome.
    • Given it happened suddenly, and when you come on boost, I'd check all your inlet - hose clamps in place and no split rubber or silicone hoses. Even the hard to get to ones near the intercooler. It's possible air that went past the air flow meter is being dumped out a big hole.
