might bitch out and run 225's on it. I'm running 215's on 9.5" rears on the ceffy, and it handles just fine. With the golf though, I want a near 60 degree sidewall to tuck in under flared out guard lip. Golfs run a factory fender flare, then a lip. Most guys homo out and just leave it as it is and try and tuck shit under it. I wanna make that lip follow the angle of the fender, then make the tyre run parallel to it.
Anyways, got the wheels. Should cost about $1300 landed. I hope. Been ages (almost a year) since I bought a set of wheels, god knows what the price of shipping is these days... and I cbf waiting for a container.
who would've thunk a Subaru Legacy is perfect fitment for a VW Golf...
looks like a spitz of some kind
lol i've got wheels and I don't even know what colour the car is... apparently I've got a choice of two, one is blue and the other is silver. choices... lol I'll probably pick the one that is cleaner.
liking the idea of blue with silver chrome wheels though... probably end up respraying it black with some ghey off centre euro racing stripe.
this is the look i''m after... minus the overdone flat black... and the wierd bits on the front bumper... maybe a smidgen higher so i can kiss the fender with the rim instead of tucking the lot like a dirty minitrucker.
gonna be baller.....
soooooooooooo i've sorted out how to fit the wheels to my ke70.... and keep it slammed (15x8-9)
flare guards 2"
castor wheels forward 1"
xt130 lca's to camber it in around 1.5"
hacksaw the fronts of the guards around 3" forward
195's
the rears need a big flare + some stretch and that's that
also i'm puttting an s series rear end on there which will act like 2 x 10mm spacers
FFFUUU suspension for both the R32 and the Golf is gonna cost me a month's pay. FML.
funky fk that vw looks like shit fitment.
Yeah he's running a 5x100 PCD to 5x114.3 PCD adapter, and even then he's settled for the minitrucker look. The Meister's I got are 5x100 PCD and have maximum allowable offset. If my calculations are right it should poke out an inch so that I can flare the guard to cover it.
Oh - what hours you working this weekend/long w/e funkeh - i comes get PC bits :down:
dunno if I cbf working this weekend... I'll chuck the mobo in the boot of the car, so just tell me when you're free and I'll come see you.
yeh should look the goods what colour is the car?
fucked if I know, I haven't even seen the car yet. All I know is that its an MK4, and its petrol, and that its gonna cost $5000. My mate's handling the buying/sourcing. Needs a VIV, but we do that day in day out, no probs.
    • Possibly avoid using a Cometic one unless the deck/head surface are perfectly flat. I did have a look just then and forgiving gaskets such as Tomei or Nitto don't exist for the FJ20, however the Bar-Tek or Kameari ones look good and might do the trick.
    • Because pipe threads for pipe things. M threads for bolt things. Throw some teflon sealant onto it and dust your hands off knowing you did the right thing, instead of going twice around the block to achieve a result using the wrong things. Of course, all of these solutions are ignoring the fact that the minimum thread pitch we're talking about here is 1.25mm, with the 1/4" in NPT or BPS being out around 1.4mm. You will need to know that the boss you're tapping has enough thickness for at least a few threads. That's one of the reasons that 1/8" is commonly used - because the pitch is <1mm. And why would you look to use 1/4" NPT in a BSP country anyway? Ugh.
    • Just throwing around ideas, does it need to be in the compressor cover? Why not the hot side piping?
    • 1/8NPT drill size = 8.7mm. Since the hole got messed up by me, it’s probably around 9mm.    So 1/4” NPT would be next step. A drill size of around 11mm would be preferred there which is not way of my M12 (drill 10.5mm and tap M12 threads)
    • 3 Kids are starting to hit that ages. I wanted to get them something special to learn on, put down the screens and have some fun. 4Door 2001 R34DE Black Pearl GV1 Jap Import, AU 2nd owner. Pre Work done. Suspension - Wheels Pedders SportsRyder Coilovers   Wheels TSG Spokey Boi 18'x9.5"+15 Body JASI Aero 4 door Type R Full Kit LED Conversion - Parker, Blinkers, & Reverse Exhaust Hurricane Headers 100 CPI high flow cat 2.5" Piping Cannon muffler Internal Bride low max stradia ii - front seats  Bride RO seat base and Rails (R/H) Cube short shifter LED Conversion - Interior
