just got done by the po-po
Told me there is zero tolerance during easter. Was friendly. Told me my exhaust sounds a bit too loud but wont send me to EPA. Also didnt give me a fine or require roadworthy. Got defected for tyres poking outside the guards :P
He told me to throw on some stockies and take it to vicroads to clear it haha They know us too well
lol nice bloke
yeah he was. I told him im not a hoon, part of car club, asaa license etc
He also checked my record and said that cause you got a clean record especially with this type of car that I believe you haha
Gave me a yellow sticker so that other cops dont pull me over too haha
fkn lucky as rekin.. almost un heard of really i got a major defect for the same thing you just mentioned :@ oh wells.. win some you lose some..
but yeh my car hasnt moved all weekend
yeah it was knox tmu. Kept asking me if i had a avcr or powerfc or any bleedie. Respect the cops and they will respect you.
I wonder how vicroads will respond to some negative camber to get them tucked under. There is nothing illegal about that? Saves me the hassle of swapping to stockies.
swap to stockies will be heaps easier..
yeh i was nice to em but i got a 30 minute lecture on stretched tyres been unsafe.. they were gay he goes your lucky we wont make you get it towed home..
im like oh well i just bought it this way thanks for pointing out how dangerous it is
meh how many times do they pull you over and NOT deliberately find something to do you for?
The last plainclothes f**kwit who pulled me over got told in no uncertain terms that I had the cat temp sensor NOT the 02 wire cut, that there was NO BOV not an atmo one (got the stock one blanked) and that he could noise test me if he thought my JASMA spec exhaust was over. I got let off, but I was pissed off that these dickheads were trying to bluff me into "admitting" to having "unroadworthy" mods.
I also had to explain that the 1998 on the build plate referred to displacement in CC's NOT the year of manufacture!
man the best i ever had was like 5-6 years ago my first 33 had a GTR wing..so it said GTR on the side the two cops debated at 8am (me trying to go to work ..) for 20 minutes whether i could drive it or not since i was a p plater im like its a gtst not a gtr twin turbo and one cop is like yeh its ok single turbo blah blah other guy went and got some manual with all the banned cars in it and says see GTR u cant drive it..im like errr its just a spoiler
such fkn retards had a good long laugh when i got to work late >.<
lol sounds like you got a drop kick.
but you are right about trying to find something. No doubt they would have found something to get me for, no chance they would let me off with nothing. Last defect was for rear brake light not in centre of window. Need to leave some crumbs around the car so they have at least something to write down and not touch the expensive fixes!
lol yeh i dont mind getting the defect etc i rkn the mechanics are worse u go in needing a RWC they just rub their hands together good chance to make some coin instead of checking u fixed what the cops list they give u other bullshit to go fix on top its such a head fk
lol i had no issues with it before but ive just started my first 9-5 job. Good luck getting a day off in the first week to clear a defect! Vicroads open on weekends?
Ive learnt not to bother even driving a N/A and obeying the laws they find something stupid.. if they want you they get you..
"pod filter isn't secure" as he shakes the shit out of it.. lols. Took that shit off and havnt had a problem really since.
    • That is way more science than even I would use. I just eyeball it, not even accounting for the non-verticality of the tape measure when held on the lip and the centre at the same time. +/- 2mm is good enough for the girls I go out with.
    • So, before putting them in I need to understand the stock ride height. This is how I measured it: First, check the diameter of the wheel's centre cap, it was 52mm. Then put a piece of masking tape approximately across the centre and measure 27mm (half) from at least 3 sides to get a reasonable idea of the centre of the wheel cap. Mark that with a horizontal line as one measuring point. Then, directly above the wheel on the guard, put another piece of masking tape in approximately the centre. Use a string line to find out the point on the guard above the centre of the wheel cap and mark that. Then it is simple, just a tape measure to check the distance from centre of the wheel to the centre of the guard. Final results where  LF: 381mm RF: 379mm LR: 401mm RR: 400mm Pretty even considering they are 120,000klm old factory springs, lets call that 380 front and 400 rear.
    • So....knowing that I have a problem with power steering temps on track and another Wakefield day booked in next Friday, I've done the obvious thing They are very reasonably priced at $1650, considering they are a big monotube shock, double height adjustable (don't have to change pre-load to change ride height), one way adjustable damping and standard sized and customisable springs if you want something other than what comes with them. They come with 9kg/mm front and 4.5kg/mm front and I went with that as a starting point because I'll add adjustable sway bars too https://justjap.com/products/bc-racing-coilover-kit-ds-ds-infiniti-q50-v37-14-current#description Unfortunately they didn't come with rear strut tops so I've re-used the factory ones which was a bit of a pain. Also, the adjuster for the rear shock will be an absolute nightmare to get at, and while there are extensions in the kit I can't see any way you can actually attach or use them
    • I also had 2 bulbs blow at once, years ago in the stagea. made for a fun drive home. The issue was the voltage regulator had failed in the alternator and it was giving 15+ volts. Really, I was lucky all that was fried were the headlight bulbs. So, I'd suggest you check the voltage across your battery terminals with the car running and warmed up. Yes, you will need a multimeter to do so, sorry.
    • Good work to think to check that, and thanks for coming back to post up the outcome.
