ah ok, the guy at importmonster told me that the offset difference wouldn't matter for GTR?
if the wheels are the same width, but have different offsets, then that's fine.
if the wheels are staggered, and the total rolling diameter of the wheel including the tyres is within 1% of each other, then that's fine too.
anything else will cause issues with ATTESA.
that red GTR looks mean!
so 19 x 9.5" +11 and 19 x 9.5" +21 if i put 255s on all 4 that would be completely fine?, might offer him 2.5k
no. you'll run the risk of fouling on the front suspension as it sits a few mm further in than normal, and it'll be about 1cm inside your fenders, so you'll ed up with flushness fail. you can run spacers if you want, that'll fix your issues, but for $2.5k I'd want it to be fucking on point to start with.
those wheels are supposed to go on V35/V36/Z33/Z34, not GTRs.
It'll work if you run spacers, and I'd only run spacers on wheels I buy for less than 1.5K. Anything more than that and I take my time to make sure I get them in the right offset, or I'm prepared to alter the car to make em fit if they're too epic to pass up.
What exactly is your job description Pat? :P Good pay for eating chocolate or nah?
haha im a process engineer at the research & develop. department within cadbury
Just started so im still going through the induction crap but I put my hand up for as many taste testing sessions as possible :D
Just started so im still going through the induction crap but I put my hand up for as many taste testing sessions as possible ;)
Ah nice. Sounds like a good job.
Well Matt has GTR front end i think anyway including quarter panels(at work cant see pics at the moment)? and seems to fill that out nicely as for rears i thought he had to pump / roll his out a bit 10" with +15 i would of thought they would look hot on a 33 GTR? might give him a cash offer ;) so Matt takes care of his bling bling? haha
On a different note i want to buy one of those 33 GTR rear defuses, carbon fiber <3 $500 from psiparts
they'll look hot, but they won't be flush.
ah fuck it, you'll probably never lower your car to epic stance anyways, so nobody will notice that they're 7mm further in than they should be.
he better be giving away a free reacharound with em at $3700 tho. or at least offer to cup your balls for a solid 5 mins.
    • I can see between the water jacket and cyl 3 there wasn't a hard line of combustion gas. It certainly appears that the issue is coming from there. Yes, checked the tension. All at 100ft lbs where I set them 5 years ago. These blocks can crack but generally when they have been over bored. Mine is only 0.5mm oversize at 89.5mm. They break between cylinders around the 91mm mark. No sign of that with mine. My gut feeling is the head gasket lifted a while back when the studs stretched and i bandaided it by retorquing the studs. It's finally let go.
    • My Nismo 1.5 churps a bit on reverse turns when cold, but besides that feels like a stock diff.
    • Yes, but, I paid cash and I'm pretty sure the receipt was in the bin 10 minutes after I got home Note to self, keep all receipts
    • Bunnings would have just handed you your money back on that one!
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
