ah ok, the guy at importmonster told me that the offset difference wouldn't matter for GTR?
if the wheels are the same width, but have different offsets, then that's fine.
if the wheels are staggered, and the total rolling diameter of the wheel including the tyres is within 1% of each other, then that's fine too.
anything else will cause issues with ATTESA.
that red GTR looks mean!
so 19 x 9.5" +11 and 19 x 9.5" +21 if i put 255s on all 4 that would be completely fine?, might offer him 2.5k
no. you'll run the risk of fouling on the front suspension as it sits a few mm further in than normal, and it'll be about 1cm inside your fenders, so you'll ed up with flushness fail. you can run spacers if you want, that'll fix your issues, but for $2.5k I'd want it to be fucking on point to start with.
those wheels are supposed to go on V35/V36/Z33/Z34, not GTRs.
It'll work if you run spacers, and I'd only run spacers on wheels I buy for less than 1.5K. Anything more than that and I take my time to make sure I get them in the right offset, or I'm prepared to alter the car to make em fit if they're too epic to pass up.
What exactly is your job description Pat? :P Good pay for eating chocolate or nah?
haha im a process engineer at the research & develop. department within cadbury
Just started so im still going through the induction crap but I put my hand up for as many taste testing sessions as possible :D
Just started so im still going through the induction crap but I put my hand up for as many taste testing sessions as possible ;)
Ah nice. Sounds like a good job.
Well Matt has GTR front end i think anyway including quarter panels(at work cant see pics at the moment)? and seems to fill that out nicely as for rears i thought he had to pump / roll his out a bit 10" with +15 i would of thought they would look hot on a 33 GTR? might give him a cash offer ;) so Matt takes care of his bling bling? haha
On a different note i want to buy one of those 33 GTR rear defuses, carbon fiber <3 $500 from psiparts
they'll look hot, but they won't be flush.
ah fuck it, you'll probably never lower your car to epic stance anyways, so nobody will notice that they're 7mm further in than they should be.
he better be giving away a free reacharound with em at $3700 tho. or at least offer to cup your balls for a solid 5 mins.
    • Lower at the hubs. Funny I forgot to mention that part. Do this pull here I turned the camera off too soon but the graph shows a drop at the top and that was because the pipe from the turbo blew off. The tuner said we could’ve made possibly another 15 whp. He also added if I switched to ethanol we could up the boost some more as well. I was comfortable capping it at the most of 20 pounds. Turns out the turbo pipe just needed a new worm clamp. Got home replaced that then did a third gear pull from 3k to 7200 rpm and the power was great to the top. I just got an ecu mounting bracket from IEE that I need to try and get everything to fit well. It’s a PITA to get the harness and ecu fit properly behind that kick plate
    • He means "as opposed to mechanical cable drive". Older cars (R32 for ex.) had cable drive. Later cars with essentially the same gearbox, ie R34 GT (NA RB25) used essentially the same box as the R32 GTSt, but instead of a cable drive, had an electronic speed sender plugged into the same hole in the box, running from the same little gear that would have run the cable. Some of the shittier later cars use a speed sender on the nose of the diff, or the ABS sensors.
    • Lower than engine, or lower than it should at the hubs? Either way, that is a nice power figure and I'm not surprised you say it rips now. What stopped you from turning it up any more? Injectors? Or did it just stop responding to boost?
    • Got my 34 gtt tuned last week. Car made 362 wheel horsepower at 19 psi. Turbo was the ATR43SS. Only other upgrades were haltech 2000 series. 650cc injectors, walbro 250, fmic. Pro hub dyno reads 6% lower than actual figure according to my tuner. Car is a real ripper now.  IMG_7261.mov
    • Hi everyone, I'm wondering if anyone in Melbourne (preferably West) has a non-S2 R34 front bar. If it's already off the car, even better!  Nothing too weird, I just need to get a cut-out of the hole that the front indicators clip into 🤣 (image attached for reference)   I've got a front bar from JSAI Aero, but those holes need to be cut myself, and I want to get it right so the indicators will clip securely. And my OEM bumper is a S2, so I have no reference. So looking for a member who might be able to spare me a few minutes to make a cardboard cut-out using your front bar.
