I've got it under control mate :P
quick question the engrish translation isnt that great you think it comes with tread?
you not gonna import through importmonster?
They charge quite a bit with fees.
http://jessestreeter.com/ Have dealt with him many times. Is cheap too.
I've got it under control mate :D
dunno, we usually strip the tyres and turf em to save on shipping weight/size. works out about the same by the time you get the rims here and put brand spankers on.
Also in the auction the guy mentions that they were put on in 2006, so they're pretty munted and pretty much should be discarded.
just keep in mind you're gonna have to dump the car to get enough camber to bring them in with these wheels. They're epic fitment, but you'll need epic stance to pull em off. otherwise they'll be mexican.
oh you work there shan?
regarding tyres makes some sense i guess some cheapys would be ok to burn through some track days tho haha
what? no.
"we" as in me and my mates who bring stuff in.
You're paying 2700ish on wheels, don't be tight, pay some coin to wrap them in decent rubbers. Also, you're gonna use these on trackdays? *facepalm*
what? no.
For a deca i would, but for like sandown / winton etc i will be wrapping the standard 33 GTR rims in some semi slicks or something similar more suited for track (dont want to be burning through 19" street tyres).
lol mexican.
yeh ill have to get it all setup correctly before i get rid of my n/a should look decent when done :D
Dear Leigh,
Congratulations, you have won the auction on item "RAYS GT C FACE1 19in10.5J 21 GT R", the closing price was 155,345¥
155 345 Japanese yen = 1 787.3009 Australian dollars (add on ~$1k for shipping)
woot woot happy :D
no fuck off. if you've made a bid with aaron don't back out now. don't screw up his yahoo rating by being flakey.
dirtbags that put down bids and then back out ought to be cuntpunched in their moodswinging sandy vaginas.
    • Brooooo Please send ABS control unit schematic Please! R33 gts25t ABS (Its two plug ecu, black and white) wire colors possible? [email protected]
    • Don't even try to run it on the stock ECU if you're going to have the boost controller bring boost above ~10 psi. I've already told you that. If you use the Nistune ECU, you will need to CAREFULLY read the available documentation for Neo tuning, and read some threads on the Nistune forums, to discover the various things you have to do to prevent the ECU from going bananas when the boost is too high. The is a table associated with th boost sensor that must be modified to prevent it from shitting the bed. This is just one of the things that you will need to do to the tune in Nistune, because the Neo turbo ECU will be expecting to see a number of things (such as the TCS) that are not there, and you have to block the DTCs on those. It is totally not surprising to me that you are having the problems that you are, but the solutions to these problems have been known for >15 years. So just get it done.
    • Hi. Sry iam not a mechanic and iam not at the car atm so i dont know 100% but they told they measure those and even try to change those. AFM they have two. Coils are new a they have my old one too. Plugs too. ECU...we have 25 NEO stock and Nistune 25 NEO.   But i dont know if any one those could be the problem and why/if/what can cause this, Only thing they did not check is fuel...but that walbro 255 is new(like 1,5 years)... That fuel pressure gauge idk...but i let them know Any suggestions?   EDIT: how can they know if it is like you say he ECU pull power when it reaches a specific boost level that is too high? Tha car has boost controler
    • Can you clarify what you mean by boost cut, do you mean it misfires both when under load (driving) and when stationary and out of gear? Or does the ECU pull power when it reaches a specific boost level that is too high (boost control issue)? Does it occur at idle with no throttle? When you say "the ECU is OK", what ECU is it and why do you think it is OK? Have you used the NEO ECU, and if so do you have a MAP sensor attached? Same for the AFM, why do you think it is OK? Do you have any way to put a fuel pressure gauge on it (even just a mechanical one between the fuel filter and fuel rail)?
