i looked at rotas.. then looked at some rota broken pics.. and like mmm..
yeh funky there +12 the bottom is +21 and looks mint enough, also low so should be ok, he didn't state any spacers.
i was thinking of buying one of the rear diffusers from psiparts, but unsure of how low they sit.. i like them but if it looks retarded with stock body then hrmm..
yeah look not a big fan of the Rota's either, but those boys have to rep the wheels they sell in their shop otherwise their customers will go "why aren't you using them if they're so good?"
but as far as stance and fitment goes, that 32's done right... even for a GTSt.
dear alex,
fuck off.
kind regards,
shan
please don't weigh in on this when your choice of cars include a poopra, a 300zx and an MR2. :P
:happy:
i like my whale anyways.. plus 32s are nice but such a small % are done right
dont all be jumping on the rota band wagon now you know they suck
Tuff fitment Alex!
Shan, what car is this?
also...
wot?
he has Face 2 +12's all around.
you have Face 1 +21's all around.
your wheels are sunken in by 9mm compared to his, AND you have lower brake clearance cos the spokes on your rim run straight and not curved (hence the different Face's). He isn't running spacers. You may have to, cos it may hit the shocks. You may not have to, you'll only find out when you get the wheels... but regardless your wheels will sit roughly 1cm further into the guard compared to his unless you run spacers.
comprende?
so could organize a half cage for me? bolt in street legal?
don't make bolt ins. race cages or GTFO. we get secondhand safety 21's from time to time... call roshan (0425855540) and find out. tell him shan asked you to call him, and also remind him that he's a giant knob jockey.
also...
wot?
comprende?
yeh i know i was just talking about the car in the bottom 2 pictures :)
I love when the R32 V R33 debate sparks up. Most of the 32 fans will find some of the best looking 32's around, post photos of them, and then post photos of white/burgundy s1's with stock wheels and no kit as a comparison, or a veilside kitted 33...
Having said that, before they start crying, I've been contemplating a 32 GTR...
lol my 32's not a looker by any means, so I don't post it up. But its like the perfect wife... knows how to take a solid beating like a champ and keeps on working without attracting attention to itself.
what? :)
although with these wheels I'm bidding on, GTR fenders, shaved bumpers, CF bits and paint, it might stand out just a touch.
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
