yehh i personally dont care so much wheels are wheels provided they arent 22" chromies its an improvement im thinkin to get drift teks or rota's for the rears when i hit the track
Yeah exactly anything better than sex spec
I love when the R32 V R33 debate sparks up. Most of the 32 fans will find some of the best looking 32's around, post photos of them, and then post photos of white/burgundy s1's with stock wheels and no kit as a comparison, or a veilside kitted 33...
Having said that, before they start crying, I've been contemplating a 32 GTR...
mmmm better be tasty like ur old car :)
work sent a email around about personal internet use :) some people have been bypassing proxy with remote desktop and going onto facebook and ruining it for everyone :D
on another note.. i need another 300 post.. 1337 then i quit the forums :)
work sent a email around about personal internet use :) some people have been bypassing proxy with remote desktop and going onto facebook and ruining it for everyone :)
I used to get around my work's Facebook filter for months :) Only "www.facebook.com" was blocked.
So I started using es-es.facebook.com lite.facebook.com touch.facebook.com m.facebook.com etc.
Eventually they twigged though ;)
I still stream music through au.myspace.com though :D They only blocked the www one.
Nice one man. Hey, question...
I have 6000 NZ addresses + suburbs, but no postcodes (can't complain, got the data for free).
Is there an easy way to get the postcodes without manually doing it through the NZ Post website? Maybe some sort of automated program?
It's all well organised in an Excel spreadsheet which could help.
NZ is retarded I swear... Within some suburbs they have like 15 different postcodes. Makes my job so much harder.
Edited by jezza boii
NZ postcode system is fubar. don't even bother. I tried to make a system for a client like 2 years ago and just returned the project with a picture of a spider and my bill for 28hours.
no you musta misheard. I hate ugly people on facebook.
I don't do MSN though.
LOL!
All my friends keep telling me to get it, but I hate it / can't be fucked with it.
Some say 'good on me for not getting it' as they are all pretty much sucked into this social networking online that consumes you...
facebook is basically only good for stalking otherwise it serves no purpose if i wanted to talk to my friends i call em and hang out iwth them if im not calling then i clearly dont give two fks about them
and i hate status updates they are lame as fk!
"just had bacon and eggs for breakky ready for a big day"
like anyone gives a fk? how important to these bird droppings think they are
/rant
+1 for stalking hot chicks though best idea ever
the only people I seem to message on fb are niggeroj, chad, kris, jizzy and AP.
which is what I do on here.
and at dinner meets.
and if I go to Seven/Alumbra etc I end up seeing them too (well maybe not kris n jizzy cos they don't play emo music at those places).
FFFFFUUUUU
/rant
We must think a like...
Exactly what I would have said.
I might get a facebook and call it "Here You Go fuck Heads! My Facebook Page" as all my friends keep bugging me. :D
FFFFFUUUUU
What music do they play there?
    • Power is fed to the ECU when the ignition switch is switched to IGN, at terminal 58. That same wire also connects to the ECCS relay to provide both the coil power and the contact side. When the ECU sees power at 58 it switches 16 to earth, which pulls the ECCS relay on, which feeds main power into the ECU and also to a bunch of other things. None of this is directly involved in the fuel pump - it just has to happen first. The ECU will pull terminal 18 to earth when it wants the fuel pump to run. This allows the fuel pump relay to pull in, which switches power on into the rest of the fuel pump control equipment. The fuel pump control regulator is controlled from terminal 104 on the ECU and is switched high or low depending on whether the ECU thinks the pump needs to run high or low. (I don't know which way around that is, and it really doesn't matter right now). The fuel pump control reg is really just a resistor that controls how the power through the pump goes to earth. Either straight to earth, or via the resistor. This part doesn't matter much to us today. The power to the fuel pump relay comes from one of the switched wires from the IGN switch and fusebox that is not shown off to the left of this page. That power runs the fuel pump relay coil and a number of other engine peripherals. Those peripherals don't really matter. All that matters is that there should be power available at the relay when the key is in the right position. At least - I think it's switched. If it's not switched, then power will be there all the time. Either way, if you don't have power there when you need it (ie, key on) then it won't work. The input-output switching side of the relay gains its power from a line similar (but not the same as) the one that feeds the ECU. SO I presume that is switched. Again, if there is not power there when you need it, then you have to look upstream. And... the upshot of all that? There is no "ground" at the fuel pump relay. Where you say: and say that pin 1 Black/Pink is ground, that is not true. The ECU trigger is AF73, is black/pink, and is the "ground". When the ECU says it is. The Blue/White wire is the "constant" 12V to power the relay's coil. And when I say "constant", I mean it may well only be on when the key is on. As I said above. So, when the ECU says not to be running the pump (which is any time after about 3s of switching on, with no crank signal or engine speed yet), then you should see 12V at both 1 and 2. Because the 12V will be all the way up to the ECU terminal 18, waiting to be switched to ground. When the ECU switches the fuel pump on, then AF73 should go to ~0V, having been switched to ground and the voltage drop now occurring over the relay coil. 3 & 5 are easy. 5 is the other "constant" 12V, that may or may not be constant but will very much want to be there when the key is on. Same as above. 3 goes to the pump. There should never be 12V visible at 3 unless the relay is pulled in. As to where the immobiliser might have been spliced into all this.... It will either have to be on wire AF70 or AF71, whichever is most accessible near the alarm. Given that all those wires run from the engine bay fusebox or the ECU, via the driver's area to the rear of the car, it could really be either. AF70 will be the same colour from the appropriate fuse all the way to the pump. If it has been cut and is dangling, you should be able to see that  in that area somewhere. Same with AF71.   You really should be able to force the pump to run. Just jump 12V onto AF72 and it should go. That will prove that the pump itself is willing to go along with you when you sort out the upstream. You really should be able to force the fuel pump relay on. Just short AF73 to earth when the key is on. If the pump runs, then the relay is fine, and all the power up to both inputs on the relay is fine. If it doesn't run (and given that you checked the relay itself actually works) then one or both of AF70 and AF71 are not bringing power to the game.
    • @PranK can you elaborate further on the Colorlock Dye? The website has a lot of options. I'm sure you've done all the research. I have old genuine leather seats that I have bought various refurbing creams and such, but never a dye. Any info on how long it lasts? Does it wash out? Is it a hassle? What product do I actually need? Am I just buying this kit and following the steps the page advises or something else? https://www.colourlockaustralia.com.au/colourlock-leather-repair-kit-dye.html
    • These going to fit over the big brakes? I'd be reeeeeeeeaaaall hesitant to believe so.
    • The leather work properly stunned me. Again, I am thankful that the leather was in such good condition. I'm not sure what the indent is at the top of the passenger seat. Like somebody was sitting in it with a golf ball between their shoulders. The wheels are more grey than silver now and missing a lot of gloss.  Here's one with nice silver wheels.
    • It's amazing how well the works on the leather seats. Looks mint. Looking forward to see how you go with the wheels. They do suit the car! Gutter rash is easy to fix, but I'm curious about getting the colour done.
