And you wanted ANL-53X on the back of your high school hoodie (or whatever you school kids do these days)
NS
Join now!
:D
f**k! its x35 LNA : :D
get it right!
got a mate whos looking for a
"already done up show car spec" supra..
*facepalm*
haha i imagine that you've just left a handprint on your mug from the facepalm
think I just facepalmed myself unconscious.
who buys wheels for a car they don't own yet.
and more importantly, who doesn't spend the money they have in their hands on a better car instead of wheels.
false advertising?
i hate all the cars with like HAYQT or SEXCGL and its like some fat fkn elephant driving that somehow managed to shoehorne there morbidly obese frame into a hyundai excel after they chucked a playboy bunny on the back window
:D
So true.
Only in thomo
yep... dont you just love thomo
anyone here go to thomo high back in the day?
because its seriously got some messed up kids
Hang on, so you bought wheels and you dont have the car?
Shotgun!!! if you dont get the car. They'll be good fitment for my 33
lol vulture
only money i ever spent on plates was on the evo
vicroads issue JDM-007 - lame yes but i was gona get pop plates anyway so for an extra $200 cant complain
meh to be honest everyone says "those plates are lame" etc etc to other car drivers when they see them and they never have personalized plates themselfs and if they do they arn't any better, limited to what you can make ;) [JDM-007] sounds good ;)
main thing i dont like is peoples names [sAMS].. just not for me..
haha there was a big war on my facebook page about the car not being JDM, even though all evo 7s are only sold in Japan
was going to try and get EVO-007 but someone already had it, still for consilation prize im not complianing haha
im more worried about your sexless life LOL.
i can only imagine the kind of hookers in thomo, oh hang on wait i can, all cock junkies with pancake makeup called jessica ;)
fixed for accuracy
nah man, tis all good ;)
but hey.. im tied down now
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
