jeremy you pedophile *roll eyes*
believe where fruit is concerned ripe is at its best yeah? younger fruit that hasnt fully flowered yet is...oh...unripe?
god knows where women are concerned 'ripe'is determined by when were our most fertile and...well...you get the picture. ie...when they stop being a little girl and become a woman. YOU have failed at finding actual women.
you can speak again once you actually have an appreciation for mature, decently formed women, not airheaded ninnies who look like they need a decent meal and a boob job kthx.
And yes Niroj, im 22. practically a senior citizen hey? thanks :(
well your halfway to 44....
if anyone wants some young ones, let me know. theres one here who wont leave me alone.. :P
I was making a joke FFS. There was NO need to say that. That was completely uncalled for and I am highly offended.
You're very lucky that I'm friends with Kris or I would not be letting this go.
Edited by jezza boii
also... wut?
^^Am I cool like you yet shan? :):P haha
admittedly...ive never had a bitch take a swing at me...
that's niggeroj you're chattin to.
get your black guys right.
Jezz are you offended cos your GF in fact has epic cans?
Whether she does or not is besides the point. The fact that anyone would make fun of a girl's breast size (not their fault what God gives them) and their metabolism (eating alot without getting fat) would just prove that they're jealous.
She's also not "airheaded" by any means. She's a very intelligent girl. Cas has never spoken to her so I don't even see where that comment came from.
(I'm not responsible for the insults below. They are a combination of kita's work and the guy sitting behind me :))
Nikita knows what was said but she just laughed. She said she wouldn't get offended by someone that shows more gum than teeth when they smile.
Cas, you like you've had too many "decent meals". And you definitely need a boob job too - a reduction and lift coz those things will be hitting the floor by the time you're 30!
always Kris isn't it? Yeah cas I'll talk shit about u disguise it as a joke and then when uve decided ur not really in the mood to have perceived flaws pointed out...you know like the fact that you're actually legal unlike the majority of the girls we talk about here...then sure i'll just tell u again ur damn lucky that ur dating this guy that I've always kinda been a little bit too into in the past. That'll work yeah?
Make no mistake...it's u that brings kris into this. I'm not hiding behind my boyfriend.
If u wanna make a joke, fine with me. Try and make it actually funny next time. For the record I dislike being compared with teenagers. It's really an unfair comparison. For them.
I'mma let you finish your argument in a sec, but am I the only on who got lost in the sarcasm of this post?
Lul wut?
I'm just saying; I don't care about your feelings, but I do value my friendship with Kris and Ian, both who I'd imagine would take your side.
I don't want to upset them so I'm being semi-nice, as much as I would love to express my true feelings here.
reading this argument is almost as fun as listening in on a discussion of cardiothoracic surgery procedures between two downs syndrome patients.
arrr ooohhhh efff ellllll
so this argument for real? :)
It kinda is "srs bizness".
I'm pretty accepting of most of the insults I cop here, but a personal attack on my girlfriend is completely uncalled for.
I'm glad she laughed at it because I certainly didn't.
    • Next, remove the upper and lower radiator hoses, both are held with a spring clamp. While you are under there, tackle the Auto Trans cooler lines.  Again both are held on with spring clamps, and as mentioned above you should cap them on the radiator side with an 8mm cap, and on the car side loop them with a length of 8mm pipe - this will stop you losing a dangerous amount of AT fluid during the rest of the job If you've been meaning to add a sender for AT trans temp, this is a great time to do it; put a sender fitting into the passenger side line as that is the inlet to the cooler/radiator.
    • Next you need to remove the intake duct (as with pretty much every job on these cars), it is a series of clips you gently remove with a flat bladed screwdriver. They do get brittle with time and can break, and I have not found a decent quality aftermarket one that fits (they are all too soft or flimsy and don't last either) but the nissan ones are a couple of bucks each (ouch).  Once the clips are off (either 8 or 10, I didn't check) you lift the intake duct out and will see the reservoirs Undo the line into the radiator side cap (some bent needle nosed piers are awesome for spring clamps) and then remove the 4x 10m nuts that hold both in place.  I didn't get these pics, but remove the line under the radiator reservoir (spring clamp again) then remove that reservoir. Then you can get at the intake reservoir, same thing, spring clamp underneath then remove it. BTW This is a great time to put in a larger (+70%) combined reservoir that AMS makes..... https://www.amsperformance.com/product/q50-q60-red-alpha-coolant-expansion-tank/ They also make an Infiniti branded and part# version if that is your thing
    • To drain the Intake Heat Exchanger, there is a crappy drain plug in front of the driver's side front tyre: You should use the largest headed phillips screwdriver you had, and in my case I needed vice grips on the hose above as the plug was tight (tighter than it needed to be, since it has an o-ring seal).  After you have a tray down and open the drain, open the intake heat exchanger reservoir cap (drivers side one) and you should get a couple of litres of coolant To get to the radiator, you need to remove the plastic engine undertray. It is held on with a series of 10mm headed bolts and some clips. For the radiator, there is another type of crappy drain (kind of like a plastic banjo bolt) and you should attach a length of hose to direct the stream of coolant per this pic (otherwise the coolant hits the rad support and goes everywhere). The drain is on the rear of the radiator on the driver's side and a bit hard to find. Put a big tray or bucket down (5l won't be enough) and slowly unscrew the fitting by hand. You only want to remove it far enough for coolant to flow, it you unscrew it right out the whole fitting and direction pipe will come off and you will get a coolant bath (yum!). Undo the radiator reservoir cap and it should empty about 8l
    • So, this shouldn't be such a mission, but there were a few tricks so I thought I'd post up a DIY for it. This was on a Q50 Red Sport but I doubt any other V37 model is very different (maybe just less steps for the intake heat exchanger hoses) I pulled the radiator out to flush it because the car was running hot at the track, but obviously the same steps apply for changing a radiator for any reason including an upgrade. If you are removing the radiator, you of course need to drain and refill, so have 5+ litres of blue coolant ready. You also need to drain the intake heat exchanger to remove the radiator so you will need a couple of litres for that as well. You will also need something to deal with the auto transmission lines, I used 2x 8mm rubber caps on the radiator side, and a short length of 8mm pipe on the car side.....unless you can block these lines quickly you will loose AT fluid and it may be enough to hurt the transmission if you don't refill it. 2 other tools that really help dealing with coolant lines and spring clamps are Bent Needle Nose pliers Hose pliers Between them they will reduce the frustration (and injury) potential by about 1000% Other than that....lets go... "First, jack up your car". Yes really, and put it safely on stands. If you are not confident doing that you need to give this job to a mechanic
    • If the forester is anything like our old 2007 GTB Liberty, I could near on run ling Long's and "rate them", as no matter what, it just hung to the road, even when abusing it in a hard launch in the wet, or throwing it at corners.
