picking a colour to respray the 32. needs to go with gold meshed/dished wheels... although I'm willing to powdercoat the centre black if I need to.
also needs to go with a black interior and underbonnet, and CF splitter, wing, mirrors etc.
I'm actually digging all the military colours... light grey, navy, army green, army brown etc.
Army Green... IMO
f**k you... craig had to rebuild the whole thing from ground up.
that's 3 years of cumulative coding redone in 6 months.
Well send him my congratulations. It looks amazing!
GTO's are getting cheap :) If it wasn't for the weight and cramped engine bay I'd probably import that 1998 one for $16k. Looks nice.
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
