be careful with shit cam gears
Racepace used to get them made locally at a fair price, not sure if that is the case these days. And that's only if your getting Racepace to work on your car.
Check with your tuner before you buy cam gears :)
im sure if done well a pump would work....
check hellaflush, i'm sure there'll be an example on there :)
had a look and there is only one black one running tuff fitment, but the way its done makes it nice
just puttin it out there best evo ive seen.
mmm i like sp1's but jsut not on an evo
needs a racey sorta wheel i reckon like te37, xd9, xt7, ce28n
Put some 34 GTR's on that mofo Nick! But chuck some spacers behind it too = mint!
I'd love an Evo 6 with 34 GTRs
yeah they expensive though, like the cost of the xt7s or cr kai's will be cheaper than the 34 gtr rims
and they need the centre hub machined out to clear the hub on the evo
however ive seen a blue evo 6 and yellow evo 8 both from interstate running them without spacers and it looks hot
depends teh look ur goin for... if it was me id be going that sleeek cruiser look like the black one but u still know it means business
the ones u posted are good to but are more in your face "im fast, racer boy" which is cool to if u like it
white bottom one looks best imo.. that second last pic bolt on flares or whatever it is.. yuk
    • So for the wide band is a Bosch 4.9 correct for the Link G4+ along with a Can bus? Just get the Link gear or is generic ok too? Eg here: LINK LINK DIGITAL WIDEBAND CAN MODULE WITH BOSCH 4.9 SENSOR : KYP Performance House
    • Bit difficult to follow. Have a look below and see what the standard R32 layout was like. Note there was a restrictor in place immediately before "turbocharged pressure control solenoid" that, if removed, magically got you 1 bar boost.
    • I might be way off the mark here.. there must be a T junction under the manifold. That takes manifold pressure through a check valve prior to the T, one side splits out to this bleed off orifice, the other straight to the wastegate actuators.
    • Carrying out some engine due diligence before my first drive in a 260RS that has been in storage for 10+ years, and found two lines that are susposed to be plumbed into the boost control solenoid. One of the lines (the wastegate boost supply line) to actuate the gates, had a bolt in one end blocking it. The other line (main boost signal line) from the very rear of the intake manifold (RB26DETT) and runs up to the boost controller had this pill in the end of it as seen in photos. Other than the obvious (T28 Ceramic turbos might well be cooked)  Can anyone shed any light on if there is any validity at all with this mod, bleeding a constant fixed rate of manifold boost pressure off through this 3mm hole?  Is it deliberate?  Was this a 90s Jap mod done to RB26's? Or has someone just fitted this without any idea of what happens to ceramic T28s if they are not gate controlled?
