my professors (18x9.5) are just on 10kg
they aint heavy wheels
call him and tell him your a mate of mine.... then watch him drop $50 of the price like that... LIKE THAT!
whodaman?
I had about an inch on you, now with 17's its about an inch and a half lol... Lets not go there!!!!
When I get back, ive got something in store for you ;)
are you sure..? haha when u get back july or soemthing?
Oh and alex, nah im not coming tonight haha. How was/is it? same shit or...?
didnt go.. was to warm in bed haha.. think it was usual shitttt been a bit better last couple weeks but a bit more attention too it seeems :down:
Yeah cool Shan!
If they want decent resale value, then yes... Yes they do :P
that aside, regardless of ur personal opinion of gtrs, they're still an icon. Kids grow up lusting after it and staring at it. Not that they don't at other skylines but it has a rep that's hard to shake. My bf's gtst makes 280rwkw and is bright orange. And it gets a lot of attention. But my stocker 190awkw gtr gets just as much awe as his does depending on the audience. First question when people see it... 'is that a REAL gtr??'
And his car as a 34 is still 40-50k 10 odd years on.
Case closed :D
Fuck I hate it when ppl ask that!
To the untrained eye, they can't see the wider guards and the GTR badge.
What makes it worst is, I don't have the OEM Spoiler and ppl just think it is a GTS-T.
Garage Cafe Audi S5..?
why don't you e85 tune it while you're at it?
in other news...
Regamaster induced boner:
:down::D
I like!
Well it turns out that the oil light was only on because the sensor is from the gen2 NA engine.. the gen3 turbo is completely different.
That's what the previous owner told me (after I just txted him about it).
I actually checked the dipstick this time and it indicates it's full haha..
BUT there is a pool of oil under the car (probably about 100ml). Could this be because I overflowed it? I only topped it up by about 100ml
Either I have epic failed or the old owner is lying.
so originally was a gen 2 NA engine ? and now a gen 3 turbo
why the engine swap?
Well the swap was done at 220,000km when the old engine was getting a bit old.
The gen3 is a much better designed engine. And well, obviously for more power!
Gen 2 NA = 117kw
Gen 3 turbo = 180kw (stock)
Mine would probably be over 200kw. Loving the power/weight ratio :down:
Gen 2 NA = 117kw
ah yeh fair call
yeah i knew they had more power, and they dont feel so restrictive up top cause they have better cams (brother was looking at buying one)
actually when he was looking he found a gen 2 with gen 3 engine we test drove in gladstone park, was red and paint work wasnt the best best
sounds similar to the one you bought
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
    • For race cars, this is one part where I find having the roll cage bar having gone through a hole in the floor better than the build it up on a ledge inside... The Merc I help on, the main hoop ends are marked on the car, and the jack is marked... Jack goes under a few inches and lifts one whole side of the car up... Removes that fight for long slim jacks for race car duties!   My biggest issue for the daily drivers I work on, is my jacks don't go high enough. The jacks start out on a few blocks, jack it up, then start a second jack under it on more blocks, and then I can get an axle stand under it. My axle stands are presently in use, and are nearly fully extended. The car is sitting with barely more than a cm of clearance to get the wheel off the studs! Sarah's Kluger is the same, as it has an ungodly amount of droop available in the suspension and a distinct lack of good jacking points!
    • Happy? Yep, my to do list is getting shorter and shorter. Either this light approaching is the end of the tunnel, or I'm about to be hit by a train... Ha ha ha   Also, Duncan isn't that far out of town that you need to make a multi day drive out of it. 😛
