hear is the list of his mods:
Trust T78-29D 14cm installed for quick spool up on the 2,700 engine, very high response even in town driving.
2,7L specification
HKS 87mm forged piston kit
HKS con rod and crank metals
HKS STEP 2 camshafts (264/272)
HKS sliding cam pulley
HKS strengthening valve spring
HKS Head gasket 1.6mm
Dynamic balanced crankshaft
Head ported and polished
Combustion chamber process (squish area removed)
Block bored to run the HKS 87mm forged pistons
TRUST T78-29D 14cm turbine
TRUST racing External waste gate TYPE-R
TRUST front pipe
Trust exhaust manifold
Essential OIL catch tank
SARD 700CC injectors
SARD FUEL PUMP RELAY
NISMO fuel pumps ×2
SARD fuel pump wiring KIT×2
SARD Fuel pressure regulator
HKS fuel rail
EAARLS fuel line
ARC pre- stage - R
SARD low temperature thermostat
Aluminium radiator cooling panel
GReddy upper radiator pipe
FULL STAGE full titanium Exhaust system (custom made)
HKS superpower flow
APEX ECV
HKS TYPE-R 3 layer intercooler
HKS intercooler piping
ARC twin core aluminium radiator
Drive train/Brakes/Suspension:
ATS Twin plate clutch
AP MINE'S 6 pot brake callipers front
355MM 2 piece brake rotors
BREMBO standard rear brakes
SEIDOYA brake pads
Stainless steel mesh brake lines
NISMO 1.5way LSD
PRO Drive 18 inch Alloys
265/35R18 93W - Bridgestone Potenza RE55S (Semi-Slick)
CUSCO front upper arm
TEIN pillow ball tension rods
QUANTUM coil over suspension
CARROZZERIA CD player
Latter-term type projector HID headlights
Racing gear 6500 Kelvin HID (Hi&Lo)
Optional OIL cooler duct in bumper
N1 front bumper duct
N1 front hood top mall
NISMO side step
NISMO rear bumper
Endless FRP Bonnet
HKS F-CON V gold PRO
Blitz dual SBC boost controller
TRUST turbo timer
Defi link controller
Defi oil pressure gauge
Defi Oil temperature gauge
Defi water Temperature gauge
Defi boost gage
NISMO full scale 320KM meter
NISMO gauges
Roll cage (new)
MOMO competition steering wheel
DU-LUCK rear cross bar
DU-LUCK rear floor bar
BRIDE ZETA-III drivers seat
Can't wait to get home. Gonna polish up my exhaust and give my interior a good clean. Getting new seatbelts tomorrow.
I love being able to work on a car again :ninja: Even if it's just detailing. The Supra has always been way too immaculate to change anything.
It looks like it was just overfill :ninja: I'll have a look under it again when I finish work but I'm 99% sure it's all good :banana:
Goes in for the RWC on Monday so hopefully not too many unknown issues.
    • That was the first session so not a lot to take from the day. It was low 20s ambient and the coolant had got to 110 (and obviously had some pressure!) so that still needs to be addressed. I haven't downloaded the data yet but will. I had refilled the auto trans with Redline DT6 because it claimed the best viscosity I could find at 100o. It wasn't really long enough to get a good feel for that; while the trans got to 100o in the session it still wasn't shifting crisply as I hoped. I think I'll try a few more sessions before judging. No steering motor overheat but I'd hope not in only 1 session! But finally the suspension; it was night and day over the standard stuff and the car was a couple of seconds quicker on the same crappy tyres, which is a huge difference. I'll stick with that and get some sway bars and a mechanical diff sorted too and see how that all goes together
    • I guess it’s partially a compromise of how my car is used, wanting to be able to switch from drift to grip with track side on-car adjustment. Also partially with the way the knuckles are set there is more static camber but less dynamic camber gain.
    • OK, so update from the track day on Friday It was a classic "an unfortunate series of events'. There were a few cars around and when i checked my mirror coming out of the fish hook I notice some smoke from the rear of mine. Looked again and it was getting much worse, I figured I'd blown a turbo or something to got off it and pulled off the racing line. However.... since it is a left hairpin into a right kink, I was on the inside of the next corner. There was a car passing me on the left and a big drop off over the ripple strip on the right......and someone had knocked the witch's hat that was on the apex about 1m onto the track. So, between those 3, I decided to mow down the cone and not damage my car/the other car. Right choice, but surprising result.  The car decided the cone was a small pedestrian so it blew the rear bonnet hinges up to protect their head in the upcoming person to car impact....I didn't see that coming and like an airbag deployment it happened super fast. Straight into the pits from there, everything was driving fine but it became clear it was a coolant leak not smoke, it was billowing up onto the windscreen. Onto the trailer and home. I'll do a separate thread about the repair (once I work out what it is ), but the immediate problem was the bonnet wouldn't open because the front was pinched onto the front bar and would not release. Ultimately we unbolted the hinge from the bonnet, pulled it back a little and it released from the front OK. "There's your problem", the top radiator hose had popped off at the radiator.
    • Yeah that looks like great caster, but I'd suggest trying less front camber some time and seeing if it helps with braking without reducing mid corner speed too much
    • I ended up setting the rear 5mm higher than normal to give some clearance.  My plan is to run the least camber I can in the rear which I think with the extra width is going to need to be -1.75 to -2.00° just to get clearance.  Guards have been rolled and pulled as much as they can/I would be wanting to.  front has the Acostal knuckle with the KPI change and the drop etc. So should be okay with the existing settings I have run with AR1s etc Front: Toe total -2mm(1mm out each side) Caster +7.5° Camber -3.8° Ackerman +15°
