noice fitment, bit small tho aren't they for a 31? they'd be sweet on a KE.
Thanks, std rims for 31 are 15, the fronts look nuts with the S13 Turbo brakes.. it fills the whole inside of the rim. no clearance issues at all with brakes / suspension etc.
haha nice rims, interesting to see how it fits once tyres are on
Picking up tyres tomorrow, hopefully I'll get a chance to fit them on this week if I can be bothered / have time. Rears will be fine, ill just give the rear some love with the hammer like I did the front. I really need some base height adjustable collies for the front now.
    • Oh, also, forgot to add these photos I believe.
    • Thought i'd update on this. I was able to get in contact with Craig Lieberman and later on Darryl Alison (owner of Kaizo Industries). Darryl was able to help me verify that my car was in fact one of theirs and is helping me find more info on mine !
