fark. im 23 and have about 2k to my name. i need to fkn graduate soon
ha i think i've caught the emo curse from you
haha the curse strikes everyone!
I graduated yesterday, got my $xx,xxx piece of paper sitting on the floor ~_~
Will be paying that off for a lonnnnng time
yo hamish, just puttin this out there, we can now import MX5 coupes.
They're a lot more structurally rigid than the convertibles and they handle like gokarts.
You want the Type A, only 40 ever made, even came with factory fender flares.
http://j-spec.com.au/wiki/Mazda/Roadster_Coupe/NB8C/id-532
that's a lotta poke on the rears, you're gonna need some epic camber and rolling to make it not look mexican.
epic camber on rear = no no, live axel :D
bolt on flares on the cards :D
the mexican look is fine, my mexican girlfriend can drive my mexican car :P I'm gonna get killed when she reads that rofl :P:D
awwwwwww, they are sooooo cute.
epic camber on rear = no no, live axel :)
the mexican look is fine, my mexican girlfriend can drive my mexican car :P I'm gonna get killed when she reads that rofl :D:)
Where are you getting your flares? Theres a guy in the UK that makes a decent set (of 4) for around 170 shipped.
My gf doesn't like being called mexican either - may have something to do with being from El Salvador :D
My gf doesn't like being called mexican either - may have something to do with being from El Salvador :(
Not sure yet, haven't started looking! Oh awesome, got a link or something?
i had no idea.... its' not like she has a mexican surname... :yes:
rofl.. the correct term is Spanish.. but Mexican jokes are funnier :D:D
Flares on Ebay
He hasn't got any up at the moment, but he makes them routinely. Just do some measuring to make sure they fit. They're pretty flexible though, have a set sitting in my cupboard
    • Omg Brake pedal removal.. FML!!
    • I mean, I can confirm the TPS is at 100%.... I can confirm when we installed the TB and setup the cable that the TB was indeed fully open at max pedal travel.. the same 'curve' (WRT MAP vs MAP) existed with the previous setup/TB/manifold as well... No, we did not do a run with no intake connected. I would love to go back in time to do such a run to rule out the intake. It would have also been good to do a run with the airbox lid off. There's a test there where increased IAT vs more available air could be a positive tradeoff. I remember taking the lid off my R34 Turbo setup back in the day and noticing a monster increase, even if IAT's did go up. Could be similar. Hard to test unless I find a very deserted road.
    • That's actually encouraging to be honest. my motor was rebuild many years ago but it's probably done less than 30,000kms and fucc all limiter or drift, majority street / drag / roll racing. It'll be fine 💪🏼 I don't even have lines or a can for the cam breathers installed yet, there is zero oil residue or splatter on or around them, it drives beautifully so it seems healthy. Just a ticky lifter, yet they're almost brand new oem genuine Nissan and haven't done many kms at all...
    • Have you confirmed the throttle body goes to WOT (and stays there) during the run?
    • I'm having a problem. I think it was mentioned above somewhere but can't see it.  I'm stuck in the cycle of, sand, filler, low spot again, put filler, sand, low spot again, now i put filler again and a thicker portion which seems to have helped but I got low spots in other areas. In the image. Circled in red thats where the original low spot was and the shape is the same as the red out line. I've more or less fixed that (still low spot up the top but now I have low spots where the green circled part is.  Is likely the issue that I didn't start with a course sand paper? I sanded the filler with 240 to reduce the risk of not going to far but maybe the issue is that I'm only taking off enough material to remove some of the filler but not the high spots. I now started sanding with 120 and I think I'm seeing a difference. I did fix one dent the other 2 are f**ked and seems like I made another low spot which is indicated by the furthest green circle on the left handside. Any thoughts and solutions?   Also second image. All of these rock chips, can they be filled in with primer or do i need to fill them all with filler/putty? So many rock chips on mine lol.
