Flares on Ebay
He hasn't got any up at the moment, but he makes them routinely. Just do some measuring to make sure they fit. They're pretty flexible though, have a set sitting in my cupboard
Your a gun thanks champ! :)
that aint poke that just plain dont fit, bolt on flares are the only answer even camber has its limitations.
foolish child, you underestimate the powah of demon camber.
Wooot! After many hours of work my audio install is complete. Farkkk it is LOUD and clear.
Over $4000RRP of shit in there. I didn't pay that much though obviously ;) Cost price FTW.
so is the amp in the front of the car? is this your lame attempt at gettin more kw under your bonnet than kris?
demon camber is bullshit
you take that back right now.
those flares aren't gonna cover all that poke if you can't camber it. Doesn't lowered spring do anything? Find a cefiro and swap the rear axle out of it.
parents usually leave their car unlocked on the driveway, they noticed on the weekend that the door wasnt closed right. Had a look through the car and noticed that the service manual + all other documents in the pouch (headunit pin number, manual, initial deposit receipt for car etc) were taken...
Nothing else seems to be missing...
What can they do with all this info? Can they get a key/alarm programmed by just flashing this book to any Mazda dealer? Something fishy going on here, cause they would have had to go up to the door to see if it was unlocked and then know to take the service book etc?
Oni Camber is the Demon!
Looks fucking mad!
haha i was borrrrreed. it in the 'my assistant' next to 'view new posts'
Ah ok cool, thanks!
this is probably old and everyone has seen it but for the ones who havn't this is the perfect drift.
Best entry of drift ever!
epic camber on rear = no no, live axel :down:
bolt on flares on the cards :D
the mexican look is fine, my mexican girlfriend can drive my mexican car :P I'm gonna get killed when she reads that rofl :happy::D
I'm not f**king mexican. Either you call me guatemalan or spanish, not mexican. I'll have to think of a way to get back at you! :):P
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
    • Yes. Autos typically work from the speed sensor on the pinion shaft of the diff. I also think that even if you have a proper speed sensor for the bog manual in the manual box, that the signal it outputs is not compatible with the auto dash anyway. You should consult that manual (the book, not the gearbox).
    • And I just realised that that advice is slightly nonsensical for a GTR, because you need 2 of them. But it is otherwise true.
    • Having had a reasonable look at the car, I'll be able to remove the (one time) rams and retract the hinge (they are held in the down location by a tiny (m3?) sacrificial screw) which will get it physically back in shape. From there if you remove the rams you need a resistor to turn off the airbag light (as Mark said, there are plug in kits and I might go that way because its reversible). And...per all the threads on here, even if you have the resistors to turn off the airbag light, the bonnet light will stay on as it writes to the airbag computer history - that is either replace the airbag controller, reprogam the EPROM (if I can work out how), or remove the globe from the dash. Having seen how sensitive this system is, if I had my time over I'd pre-emptively remove the rams, even on a road car, because this is all a very unnecessary pain in the arse. Reminds me, time to go and have a look at the Fuga too....
